November 7, 200916 yr TuneUp Utilities 2010 v9.0.4700.25The complete tuning solution for your PCWith TuneUp Utilities, your system will be faster, more comfortable and more secure. All important aspects of system configuration, security, cleanup and maintenance can be accessed through a modern graphical interface.TuneUp Utilities will optimize the performance of your PC, solve problems and help you easily customize your computer to suit your needs.TuneUp Utilities helps both beginners and experts to make Windows meet their needs in a way that is better, easier and safer. All important system options are explained in an easy way and can be turned on or off at the click of your mouse. TuneUp Utilities will then make the necessary changes in the registry or boot files automatically. We place a high value on system stability, so that Windows won't stop working reliably. And most changes that you make can be undone in TuneUp Rescue Center - easily and safely.TuneUp Utilities also gives you many more options. In addition to helping you make Windows "better looking", you can also clean up and optimize your system at the click of a mouse. TuneUp Utilities 2008 will clean up unnecessary data from your hard disk and remove unnecessary entries from your registry. It can defragment your hard disk and registry and optimize your system settings to make Windows run substantially faster. Most of this maintenance is performed automatically every week by TuneUp 1-Click Maintenance.Automatic adaptation to your operating systemWhen making these changes, TuneUp Utilities reaches deep into the Windows system. However, Windows has changed a great deal from version to version. Because of this, the software automatically recognizes and adapts to each supported version of Windows. This is done automatically so that you, the user, won't have to re-learn the software for each operating system version.Svcpack Addon Downloadhttp://www.mediafire.com/?yedi2oj4d4a3ai7Size:16.3Md5:039915bb9991fad9e117afe0c8ecfc04Switch Installer Downloadhttp://www.mediafire.com/?snwgzhxb2ykzsysSize:16.2Md5:a44618aece93f5968962b54efae5a631To add Registeration Info open the exe and extract TuneUpReg.regopen it and add the info you need then readd it to the exe file with 7-Zip Edited October 8, 201015 yr by DaRk MaDnEsS
November 7, 200916 yr hi, :worthy: thanks!!! i was havin a right nitemare with this 1 ended up usin Autoit, nice 2 c some1 cracked it!EDIT- still gettin german lang in the taskbarEDIT- fixed! all that was need was a restart :doh: cheers james Edited November 7, 200916 yr by jamesbebby
November 7, 200916 yr hi, :worthy: thanks!!! i was havin a right nitemare with this 1 ended up usin Autoit, nice 2 c some1 cracked it!EDIT- still gettin german lang in the taskbarEDIT- fixed! all that was need was a restart :doh: cheers jameswell it was a bit tricky to extract the msi files and about the german taskbar if you see the registry you would see i included a fix for it that sometimes needs restart to work ( and i see you made the restart)i hope you like it as some people needs this addon and like the tool like me
November 7, 200916 yr Excellent work. This addon is really very difficult to do. No german lang in taskbar and the possibility to insert the own serial.Congratulations Edited November 7, 200916 yr by arsenalz
November 13, 200916 yr config.txt;!@Install@!UTF-8!Progress="No"RunProgram="TU2010.MSI /qn MODIFYREMOVE=modify"RunProgram="TULANGPACK_EN_US.msi /qn MODIFYREMOVE=modify"SetEnvironment="hklm_rdr=HKLM\\Software\\TuneUp\\Utilities\\9.0"RunProgram="hidcon:cmd /c reg add \"%hkcu_rdr%\" /v Company /t REG_SZ /d xxxxxxxx /f"RunProgram="hidcon:cmd /c reg add \"%hklm_rdr%\" /v UILanguage /t REG_SZ /d en-US /f"RunProgram="hidcon:cmd /c reg add \"%hklm_rdr%\" /v UserName /t REG_SZ /d xxxxxxxx /f"RunProgram="hidcon:cmd /c reg add \"%hklm_rdr%\" /v ProductKey /t REG_SZ /d xxxxxx-xxxxxx-xxxxxx-xxxxxx-xxxxxx-xxxxxx /f"RunProgram="hidcon:taskkill /f /im TuneUpUtilitiesService32.exe"GUIMode="2";!@InstallEnd@! Edited November 13, 200916 yr by remek002
November 13, 200916 yr config.txt;!@Install@!UTF-8!Progress="No"RunProgram="TU2010.MSI /qn MODIFYREMOVE=modify"RunProgram="TULANGPACK_EN_US.msi /qn MODIFYREMOVE=modify"SetEnvironment="hklm_rdr=HKLM\\Software\\TuneUp\\Utilities\\9.0"RunProgram="hidcon:cmd /c reg add \"%hkcu_rdr%\" /v Company /t REG_SZ /d xxxxxxxx /f"RunProgram="hidcon:cmd /c reg add \"%hklm_rdr%\" /v UILanguage /t REG_SZ /d en-US /f"RunProgram="hidcon:cmd /c reg add \"%hklm_rdr%\" /v UserName /t REG_SZ /d xxxxxxxx /f"RunProgram="hidcon:cmd /c reg add \"%hklm_rdr%\" /v ProductKey /t REG_SZ /d xxxxxx-xxxxxx-xxxxxx-xxxxxx-xxxxxx-xxxxxx /f"RunProgram="hidcon:taskkill /f /im TuneUpUtilitiesService32.exe"GUIMode="2";!@InstallEnd@!well i know i can use config but it wouldn't be easy for every one i already finished the new version it's compress with 7zip but still the Reg file exist it's easy for every body and if you want to make your own post a topic for it
November 19, 200916 yr Hello,could you do in French please ?well ok just give me the link and i would do it
November 19, 200916 yr I do not understandlook up you would find Download-Fr that is the french version
November 19, 200916 yr I do not understand at all, it's okay forget my request.dans le poste principal que vous trouveriez Download-Frqui est la version fran
November 25, 200916 yr It would be great if we could add our extra tune up styler logon and boot screen and changing it during unattended . Is that possible?
November 25, 200916 yr It would be great if we could add our extra tune up styler logon and boot screen and changing it during unattended . Is that possible?well when using the Boot screen with Tune up it creates a file name TUKernal.exe out of your ntoskernl that can be replaced with the one in the xp cd and the same goes for the logon but i can't recall the names right now
November 26, 200916 yr well when using the Boot screen with Tune up it creates a file name TUKernal.exe out of your ntoskernl that can be replaced with the one in the xp cd and the same goes for the logon but i can't recall the names right nowI know that but does this means that it will work, if I replace the NTOSKRNL on an integrated cd with windows updates? Edited November 26, 200916 yr by stsaerox
November 26, 200916 yr I know that but does this means that it will work, if I replace the NTOSKRNL on an integrated cd with windows updates?well it was working only needed tp modify pe it then replace it
November 26, 200916 yr Dark...there are new version: TuneUp Utilities 2010 v9.0.2020.2: http://download.tune-up.com/TUU2010/TU2010TrialEN-GB.execheers
December 13, 200916 yr Hey DM do you know the name of the temp folder where I can retrieve the MSI for this program, I cant find it and I need it for Spanish version
December 13, 200916 yr Hey DM do you know the name of the temp folder where I can retrieve the MSI for this program, I cant find it and I need it for Spanish versionopen with 7 zip.rsrc ---> RCData -- > extract both msiand rename the end with msiyou need to use version 9.07 or higher
December 14, 200915 yr WOW that is greatthx well i kind found this way by chanceand i think it's the only solution i found until now
January 23, 201015 yr Can you tell me please if there is any way that I can apply my custom desktop icon package silently during windows installation?
January 31, 201015 yr The last version is now 2010 v9.0.3000.136.But Tuneup.com altered one of Tuneup Utilities's best resources. They removed the possibility to win space in disk, eliminating the uninstall of Windows Update Hotfixes. After all who does uninstalls Windows Update hotfix? We had this option ...and now, no more.Up to version 9.0.2010.11 that was possible. Now they took that option and according to several users, it was not good. I still using the v9.0.2010.11 and not tried to make addon for the new version v9.0.3000.136. I noticed that impoverished this app. I'll leave it alone.I suggest to you DaRk MaDnEsS, that informs the users in case you decide to do the addon-update of the new version.Apparently this may seem unnecessary, but I think it would be of great value to all, just because only you worked addons for this app. Thanks.Cheers
