December 31, 200916 yr Hi, I have been having, for a week or two, the weirdest problem ever. Let's say I try to follow a link in PCWorlds newsletter, I then get an error message saying:"Connection Failed. Firefox cannot connect to the server at Reviews and News on Tech Products, Software and Downloads - PC World.- The site may be temporarily down, try again etc. etc.The message comes up immediately, no trying with subsequent time-out, just bang - head against the wall.Same difference with Internet Explorer.The weird thing is that it's only PCWorld.com I cannot connect to, all other sites (this one, for instance) work fine.I just can't remember what I might have done to exclude myself from PCWorld.Can anybody out there guess what's the matter?Thank you!
January 1, 201016 yr What are you using for system protection. Which Anti-Virus or/and firewall?For instance NOD32 has the option to block some sites if I remember correctly.
