March 13, 201016 yr hi. i just want to create unattended.xml wihich is include this sections only (i did not understand how to craete and edit the xml file.)cd key,windows 7 ultimate, tr-TR,andrunonce command e.g: %systemdrive%\install\runonce.cmd.i dont want anymore for unattending (user name company name etc). i will create a runonce.cmd it include silent installation command for software and drivers. and last what folder will i put the unattended.xml file in win 7 dvd? and do i need to edit install.wim file for unattending windows ? thanks
March 13, 201016 yr You dont need to edit install.wim to make your DVD unattended, here is a good guide to start to learn how to make your xml (its for Vista but its pretty similar)http://www.mediafire.com/?mk5zmm2ymgl
