March 24, 201015 yr it is the main error who can solve itThe system DLL user32.dll was relocated in memory .the application will not run properly . the relocation occurred because theDLL c:\windows\system 32\shell32.dll occupied an address range reserved for windows system DLLs . the vendor supplying the DLL should be contacted for a new DLL
March 24, 201015 yr Author Why is this posted here? Where should I move this topic?i am sorry that i posted in here the shell32 its 25 megabytei change the icon and just the dialof in line 1020
March 24, 201015 yr If you pass a certain size when you patch shell32.dll you will get this error when you try to install some programs
March 24, 201015 yr Author If you pass a certain size when you patch shell32.dll you will get this error when you try to install some programshi rici will finally find youit is my chanse too finding youok dear rick i unattended win xp sp3 with Nlite and i change shell32 who can i solvethis problem.and who can i have a gap with you in private ? about win xp
March 24, 201015 yr You can solve it by reducing the size of your shell32.dll, by removing only the high resolution icons from your .ico files, also the avi's try to shrink them or use smaller sized onesI also had this problem and you can see that I solved it by recompressing my avi's http://www.msfn.org/board/topic/113295-req-help-make-move-copy-delete-avis-smaller/
March 25, 201015 yr Author you are the best dear ricktendo exactly it was belong the size this errorthank you yesterday i solved it .when the size decreased in 32 mg up to 21 the errore resolved.mr ricktendo can i ask another question in here like .ehis link to download can,t be downloaded(Invalid or Deleted FileThe key you provided for file download was invalid. This is usually caused because the file is no longer stored on Mediafire. This occurs when the file is removed by the originating user or Mediafire. If you believe you have reached this page in error, please contact support.Click here to view our help resources) Edited March 25, 201015 yr by rebi
March 25, 201015 yr Author http://www.msfn.org/...e-avis-smaller/ this file dearand dear rick do you have an any regstry tweak or somthink like that for optimizing win xp just for increase speed in xp
March 25, 201015 yr Original: http://www.mediafire.com/?wdm0yzlukfyCompressed: http://www.mediafire.com/?mz1m2bvayzzNo, dont have any regtweaks for XP
March 25, 201015 yr Author thank you again Mr ricktendo641)how can i add Vista Aiero Cursors to win xp in cdand dear i did not any different between both of link .they are the samefinally i found it 2) http://rapidshare.com/files/79830715/VistaAVI_VNO.7z without any type . Edited March 25, 201015 yr by rebi
March 25, 201015 yr Author thank you again Mr ricktendo64finally i found it 3) http://rapidshare.com/files/79830715/VistaAVI_VNO.7z Edited March 27, 201015 yr by rebi
March 26, 201015 yr Author I think you are so busy to replay but if you want to replay me for doing something tell me i will do it.thanks .the before post i told my question
