April 9, 201015 yr For some reason my moms wireless connection will only work under the Admin account. I have uninstalled and deleted the software and drivers, CCleaned and reinstalled software with no luck.Thanks
April 12, 201015 yr Hm, I've actually always used wireless with Admin account, I never tried to use it with lower permissions. I've found on some forums that this is a windows bug, as sometimes it is working.Try to delete that user profile and create a new one. See if that helps.
April 12, 201015 yr Author Thanks N1K. I ended up uninstalling to dongle's software and it works fine through Win7's wireless connection.
April 12, 201015 yr Author So it was a driver/software issue. Good to know for future reference.The driver was fine. The Trendnet program it's self as showing disconnected on all accounts other than Admin. but I later found it still connected jut showed up as disconnected so I never checked.
