May 6, 201015 yr Resource HackerDescriptionResource Hacker is a freeware utility to view, modify, rename, add, delete and extract resources in Windows executables and resource files (*.res). It incorporates an internal resource script compiler and decompiler and works on Win95, Win98, WinME, WinNT, Win2000 and WinXP operating systems.Version: 3.6.0.92Addon Release Date: October 2, 2012Uninstallable: YesCredit: *Reaper* (x64) 438 kb 74d5ef645f59c0ca7997f6a2f512f90b (x86) 438 kb 2031b4d0d35d0daec4e669a2960bb67cEnjoy! Edited October 3, 201213 yr by *Reaper*
October 6, 201213 yr Thanks for this awsome addon, I Installed this on a fresh Win 7 x64 install. Right click on *.EXE or *.DLL 'open with' ResHack does not work.Choose the program you want to use to open this file...Browsing to the %Program Files%\Resourse Hacker\ResHack.exe does'nt fix it either. Also the checkbox 'Always use this program to open...' is greyed out.I've looked over the code in your inf install file but can't seem to pin-point the problem.I will try on fresh x32 install and report my results. Edited October 6, 201213 yr by dotfusion
October 9, 201213 yr Thanks repaer, I tried again today on another machine without hickups. Must be issolated to my one mahine. Thanks again this great addon.
October 25, 201411 yr Thanks *Reaper* for this nice addon, but why not FX it( I mean the Resource Hacked FX improved version)?: http://rammichael.com/resource-hacker-fx Edited October 26, 201411 yr by niTe_RiDeR_Pro
