Bug with nLite [registry_addreg] ?
Hello
I use a entries_.ini file to add custom tweaks with nLite
(view http://www.nliteos.c...registry_addreg if you don't know what i'm talking about)
The problem lies in this line:
HKCU,"Software\Microsoft\Internet Explorer\SearchScopes\{1C5F694D-B965-4AEA-AF33-8906DFBC21E4}","URL",,"http://www.google.fr/search?hl=fr&q={searchTerms}+&meta="
Becomes this in hiveset.inf, HIVEDEF.INF and nlite.inf (also, why nLite add the keys to all these files? nlite.inf is enough....)
As you can see, nLite truncate the end,(+&meta=" ), resulting in an error at the text mode stage of the install:
If i manually edit nlite.inf to add my tweaks, everything works fine, but that's a hassle to do this at each integration.
So, is this a know bug or limitation of nLite?
Can i avoid that ?
Thanks.
Edited by mooms
Thanks for the answer ricktendo64, that's also my guess.
I have finally made an addon with an inf file which does the addreg. Works well.
And that don't "pollute" all these inf files like nLite do when using [registry_addreg]
I really don't understand why nLite duplicate the entries in all those files when nlite.inf is enough to do the trick.
But i have a little cosmetic glitch caused by my inf addon:
it sow up in this window: (don't know the name in english, must be add/remove components)
here is my addon:
http://www.mediafire...zjh6jso957ngqn3
Can you tell me why it shows up there ? i can't find the mistake in the addon....
Regards.
Edited by mooms
