Silent Install - Move Installation Files
Nope, all of them must be on the DVD root, this will reduce the wim image size and easier to update the apps.
Note/EDIT: You can once the process has finished move the Apps folder from the dvd to a partition, usb stick, etc... and during install it will ask you to locate it :)
Edited by Legolash2o
