Integrate drivers with foreign characters
I have implement some new methods in AIO tool. You will see a list with three options which are:
Imagine you have selected a driver at D:\Drivers\Display\driver.inf
Method 1 - (Fast)
This will use the current style of integration and is good for drivers with no foreign characters. Dism will use 'D:\Drivers\Display\driver.inf' so this is the quickest.
Method 2 (Medium) :: Default
This is set as the default option, basically this will move the driver to the root of the drive to something with simple characters and install from 'D:\W7TDrivers1\driver.inf' Don't worry it will move the folder back afterwards.
Method 3 (Slower)
This is the same as method 2 but will copy the folder instead of moving and then delete that folder after.
