[Solved] WU Cabs Shows Red
Using v26 the new Windows Update Agent Cabs show red but also show integrated... not sure yet if they did or didn't install but I will run the KUC and know soon
post-11313-0-45713100-1339327027_thumb.j
post-11313-0-87887900-1339327048_thumb.j
I remember I asked in the past for a previous build Lego to make those cabs turn green since DISM integrates them. However, now they're updated, so...
LE: Actually, komm uses a different file name for those files. I'm pretty sure if you rename them so they'll match the name of the cabs from SoLoR's repository they'll turn green :) |WinToolkit is already modified for those names...
Edited by RicaNeaga
