[Solved] WIM Manager, help importing image...
I have a problem in WIM Manager, when I want import Image from existing WIM, the Browse button in disable... I'm doing anything wrong...?
Regards... ;-)
post-27023-0-67712700-1339956948_thumb.j
post-27023-0-34731000-1339956954_thumb.j
Your image is modified and not original. Because of this it can happen...
Thank's for your repply... :beerchug:
I know what the problem is, I was doing wrong. What I wanted was to add an image to another, but is done with export image, not import image... X-D sorry... :cap:
Regards... ;-)
