ISSUE: CAB Integration
For some reason *.cab files are not being integrated, anyone else having this issue?
EDIT 1: This issue only appears if you are going to integrate IE9 or have integrated it the past, once IE9 is integrated, CAB updates will no longer work :(
EDIT 2: It seems to also affect MSU files when LDR/QFE mode is selected.
P.S. I am currently using Windows 8 so that may be the problem.
hi lego going back to windows 8 ill repot back as soon as i get home from work.proberly just after midnight.if my mind serves me correctly this scenario also happened with some of mcrip cabs also.i make another image and test for you.
