[Solved] Guest
I've been seeing this a LOT when I use http://www.wincert.net/forum/index.php?app=core&module=search&do=viewNewContent&search_app=forums. Today, just now, I noticed that Reaper is listed on that page as "Guest" for ALL the threads he updated over the last week or so - 8 or so posts, though his avatar is correct. When you go to the actual thread he is listed correctly. Usually it is Rick that is the "Guest". I haven't really figured out the pattern, but it did start this behavior fairly recently, maybe a few weeks ago.
