May 22, 200718 yr Here are my Internet Explorer 7 Addons (for Windows Xp SP3 English) with following IE7 updates integrated: KB928090, KB938127-v2, KB956391, KB958215, KB960714 Addons are compatible with RVMi 1.5.3 and nlite 1.4.9. (No backwards compatibility)IE7 Addon:Totally safe. However, this addon replaces a few IE7 files at OOBE. (imgutil.dll, inetcpl.cpl, inseng.dll, mshtml.dll, msrating.dll, pngfilt.dll, webcheck.dll)Download: OR: MD5: 8929DDE401D80A573E952FADCA987CE0 / File size: 9,71 MBIE7 Alternative Addon:This addon will integrate all IE7 files directly to your Windows source w/o OOBE.Download Alternative: (alternative) OR: (alternative)MD5: 2553965B0C04F5E416E69EC740B6CE57 / File size: 9,34 MBOff-Topic Comment(Click to Show) Changelog:2008-12-18 v2.0.4a: Added KB960714.2008-12-15 v2.0.4: Added KB958215 (obsoletes KB956390)2008-11-08 v2.0.3: Added KB956390 (obsoletes KB953838) & Added KB956391 & Updated KB938127 to KB938127-v2.2008-09-08 v2.0.2: Added KB953838 (obsoletes KB950759). & Added IE Desktop Icon setting in Folder Options menu in Control Panel. & Removed IE Desktop Restore icon fro start menu.2008-06-19 v2.0.1: Added KB950759 (obsoletes KB947864). & Added "SP3 WBEM Fix AddOn v1.1" (readding the addon will not create a problem) & Removed some files for more sp3 compatibility (browseui.dll, jscript.dll, shdocvw.dll, shlwapi.dll, vbscript.dll)2008-05-31 v2.0.0: Full XP SP3 compatibility. No more compatible with XP SP2. & Removed xmllite.dll and custsat.dll from the addon. They exist in sp3 release. & Added IE Desktop Icon, also added a shorcut, Internet Explorer Desktop Icon, to "Start/All Programs/Accessories/System Tools" that will add IE icon to desktop again.2008-03-06 v110: Full RVMi 1.5.1 compatibility. Removed backwards compatibility. Not compatible with older versions of RVMi 1.5 and RVM Update Pack 2.2.1. & Removed modified IE.inf and IEACCESS.INF files from addons. Now using ExtraFileEdits in order to modify them.[Close]Important Notes:These addons will integrate IE7 into your windows source. Can NOT be uninstalled.Not for use on a running windows installation.Contains "SP3 WBEM Fix AddOn v1.1" in order to prevent possible errors. Re-Adding the Fix addon will not create a problem.Both addon don't contain these files from original IE7 installer: browseui.dll, jscript.dll, shdocvw.dll, shlwapi.dll, vbscript.dll, xmllite.dll. XP SP3 release contains newer version of these files.The alternative addon should be fine, particularly if you prefer to overwrite files and disable SFC with nlite. This addon produces 'setuperr.log' messages about these files (imgutil.dll, inetcpl.cpl, inseng.dll, mshtml.dll, msrating.dll, pngfilt.dll, webcheck.dll). So far, they seem negligible. We're working on it!If you're adventurous, go with the Alternative Addon. Otherwise, play it safe and go with the normal Addon.Comments, bugs, reports are all welcome. Thanks for your co-operation.=====About IE7 tweaks: No tweaks are included in the inf file. You can see this thread for some. Copy the codes you want, and paste them under "[userTweaks.AddReg]" in NR_IE7en.inf file. (Its at the end of the inf file.)For adding IE7 tweaks for ALL users in your system:Add your tweaks normally in NR_IE7en.inf file. (This is for first user.)Open xIE7en.inf file. Add your tweaks in that file too. At bottom of the file, under ;Copy & Paste your IE7 tweaks here below.[userTweaks.AddReg]Then search for ;AddReg=UserTweaks.AddRegand change it toAddReg=UserTweaks.AddRegSave and close xIE7en.inf file.After re-building and using that addon, you will have your tweaks aplied to all users created in your new system.=====About IE Desktop Icon:If you don't want to disable IE Desktop Icon creation, you need to modify these lines in NR_IE7en.inf file only:HKCU,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\ClassicStartMenu","{871C5380-42A0-1069-A2EA-08002B30309D}",0x10001,0HKCU,"Software\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\NewStartPanel","{871C5380-42A0-1069-A2EA-08002B30309D}",0x10001,0HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\ClassicStartMenu","{871C5380-42A0-1069-A2EA-08002B30309D}",0x10001,0HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\NewStartPanel","{871C5380-42A0-1069-A2EA-08002B30309D}",0x10001,0 to HKCU,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\ClassicStartMenu","{871C5380-42A0-1069-A2EA-08002B30309D}",0x10001,1HKCU,"Software\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\NewStartPanel","{871C5380-42A0-1069-A2EA-08002B30309D}",0x10001,1HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\ClassicStartMenu","{871C5380-42A0-1069-A2EA-08002B30309D}",0x10001,1HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\NewStartPanel","{871C5380-42A0-1069-A2EA-08002B30309D}",0x10001,1If you don't want the icon for later created users after first user, modify same strings in xIE7en.inf file too.=====PS: Do not modify the entries in NR_IE7en.inf file without knowledge of what they do.See this thread on RyanVM.net for the development of this addon. Edited December 23, 200817 yr by MrNxDmX
May 26, 200718 yr MrNxDmX just wonted to thank you for this and many other addons that you make. I'm glad you finaly decided to copy your projects to wincert, as me and many others are not registered on RyanVM forum,but monitor it very often. Regarding this addon (IE7) I'm using alternative addon v1.0.5.b and I must whoohoo :lol: Keep on with your good work. :notworthy:
May 28, 200718 yr Author Thanks Gorki. I'm glad you like my addons Updated to v105c. More info in first post.
June 24, 200718 yr Thanks MrNxDmX, always clean and smooth..no problems using .alt solution :thumb_yello:
June 24, 200718 yr Author Thanks MrNxDmX, always clean and smooth..no problems using .alt solution :thumb_yello:Thank you too. Nice to hear that there is no problem.
July 13, 200718 yr Updated.I just Integrated the IE7 Addon and working flawless...Who will need the alternative version ?I never need it actually, Every time i just pick the standard IE7 Addon...Really very appreciating work MrNxDmX.... :thumb_yello: Thanks....
September 22, 200718 yr Now I am wondering why do you get these messages in setuperr.log imgutil.dll, inetcpl.cpl, inseng.dll, mshtml.dll, msrating.dll, pngfilt.dll, webcheck.dll, I see you said "we're working on it" well have you found anything ?Sull
September 22, 200718 yr There is another version of the IE7 addon, its been updated too. This one is needs updating.http://www.ryanvm.net/forum/viewtopic.php?t=4847
September 25, 200718 yr There is another version of the IE7 addon, its been updated too. This one is needs updating.http://www.ryanvm.net/forum/viewtopic.php?t=4847Hi Ricks!OnePiece is a friend of mine and I have talked with him so if you like this IE7 addon, you may host it. I could start a new topic so I'll be able to edit the first post. Reply, please.kontini Edited September 25, 200718 yr by kontini
January 18, 200817 yr Author 2008-01-18 v107: Added KB938127 (Replaced KB929969). Added KB942615 (Replaced KB933566)Edit:Now I am wondering why do you get these messages in setuperr.log imgutil.dll, inetcpl.cpl, inseng.dll, mshtml.dll, msrating.dll, pngfilt.dll, webcheck.dll, I see you said "we're working on it" well have you found anything ?SullBecause they dont have dllregister section inside. The only thing i know is this. Edited January 18, 200817 yr by MrNxDmX
February 26, 200817 yr Author Updated to 1.0.9a. 2008-02-26 v109a: Removed plugin.ocx from obsolete files, now using reg keys to delete it, thanks HJW. Added KB947513 related entries.Addons are not yet compatible with RVM Integrator 1.5 releases. Will do a version change after release of RVMi 1.5. Edited February 26, 200817 yr by MrNxDmX
March 21, 200817 yr Author I've forgot to update this topic Addons are updated to 1.1.0 release. Fully compatible with RVMi 1.5.1, no backwards compatibility (Not compatible with RVMi 1.4.3)Check first post for more details.Off-Topic Comment(Click to Show) 4 mirrors LOL[Close] Edited March 21, 200817 yr by MrNxDmX
