December 19, 200718 yr How to enable AHCI on Intel ICH9 under XPAfter some research, we have a working solution to enable ACHI on the ICH9 with appropriate SATA/NCQ drive(s).For more information about AHCI, we refer to Wikipedia.org:The Advanced Host Controller Interface (AHCI) is a hardware mechanism that allows software to communicate with Serial ATA (SATA) devices such as host bus adapters which are designed to offer features not offered by Parallel ATA (PATA) controllers besides higher speeds, such as hot-plugging and native command queuing. The specification details a system memory structure for computer hardware vendors in order to transfer data between system memory and the device.List of needed files and driver packs:MagicISO32-bit Floppy Configuration Utility for Intel
December 21, 200916 yr That's a best post for us less mortals who want to upgrade to sata drives instead of spending a few more thousands on the comp.Thanks again admin for the nice post.
May 30, 201016 yr I have installed sata drive in my computer.The drivers are not found in the intel site .Requested to prvide link to download drivers.
May 30, 201016 yr Yes, the download link in the first post doesn't work.Here's a link to current drivers for all OS. (select link for "Drivers" or "Utilities, Tools and Examples")http://downloadcente...2-bit+floppy%22Make sure you select the correct one.For current-series boards, the link is here.http://downloadcente...=18860〈=eng Edited May 30, 201016 yr by Mr_Smartepants
July 6, 201412 yr does anyone know where i can find all the latest windows xp post installation drivers for sata/achi/raid/usb3 so i can integrate them-slipstream with nlite? Edited July 6, 201412 yr by symbios24
