Windows Defender
Info: Editable RunOnceEx Switchless SFX Installer. You can easily add the Updated Defs from your PC into the WindowsDefender.exe installer.
Installer is updated with 3/26/2008 Spyware Definitions (you can take it from here on :))
MD5: 7161B3B3B1BF0574C9BA7D6258C6ED06
How to update:
U p d a t i n g  I n s t r u c t i o n s :
1) Open the Installer with WinRAR
2) Go a bit deeper (in WinRAR) into the this installer's sub-folders
"Application Data\Microsoft\Windows Defender\Definition Updates\Default"
3) Copy the following in Run...
"%AllUsersProfile%\Application Data\Microsoft\Windows Defender\Definition Updates"
4) Locate the folder containing the latest updates (look for something like "{XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX}")
5) Drag & drop those updated definitions (mpasbase.vdm, mpasdlta.vdm and MpEngine.dll) into the opened with WinRAR "Default" subdir
6) Hit "OK" and you are done
Note: You can only install this program once you logged into windows, it is NOT! svcpack compatible.
Changelog:
3-27-08
- Updated with latest defs 3/26/2008
- Now uses TRANSFORMS to stop the program from launching after install
There in
%AllUsersProfile%\Application Data\Microsoft\Windows Defender\Definition Updates\{XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX}
The X is to represent a number
%AllUsersProfile% = X:\Documents and Settings\All Users
Hey,
I think this is the best idea, suggest your users do a find and replace. There are only two instances of the folder name in your *.cmd file.
laze.
Edited by just_laze
Or I could just update the cmd file everytime an update comes out...
But I dont think its the same for each uses, I think windows generates the folder name randomly
Hey,
Would it be possible to prompt the user to enter the folder name where their definitions are located, store this as a variable and use it in your batch file.
windows defender/deffoldername$
Something like that?
laze.
  • 1 year later...
  • 1 year later...
