February 24, 200719 yr This small prog creates the same 3D effect as in Windows Vista!Find windows, fast.TopDesk is a quick and easy way to switch between applications.With a single key press, you can instantly view thumbnailsof all open windows, display thumbnails of windows belonging to the current application,or hide all windows to quickly access the desktop.FeaturesDisplays thumbnails of all applications,including minimized applications, in 2D and 3D views.Shows thumbnails of all windows belonging to the current application.Hides all windows for quick access the desktop.While tiled, can display the title of the currently selected window or the titles of all tiled windows.Windows can be closed and minimized/restored while tiled.Completely configurable: Hot keys, mouse hotspots, floating buttons,window titles, and performance settings can all be changed.Supports multiple monitors. Downloador you can get it from here:Windows_XP_3D_flip_effect.zip
February 24, 200719 yr I post only freeware That sendspace link confused me, just like Rick too Sorry.
February 28, 200719 yr Can you reupload it to somewhere, please?The file has been deleted. Unfortunately, it did not comply with the terms of service.
February 28, 200719 yr Interesting software, I'll give this a try on Vista Home Basic Nope, doesn't work Edited February 28, 200719 yr by cygnus
March 27, 200818 yr woo!hell yeah!after finaly patching my uxtheme, thanks to linux, and downloading the vista transformation pack, this is the last step to making my XP as vista as possiple i danm hope it works.
March 31, 200818 yr Hi All, after downloaded. My antivirus told this was the downloader viruses in TDS.exeDo you have this problems?My Antivirus is Symantec Client Security.
March 31, 200818 yr Author Hi All, after downloaded. My antivirus told this was the downloader viruses in TDS.exeDo you have this problems?My Antivirus is Symantec Client Security.No Viruses.Try to scan with other Antivirus software.
March 31, 200818 yr Run away from Symantec! Hi All, after downloaded. My antivirus told this was the downloader viruses in TDS.exeDo you have this problems?My Antivirus is Symantec Client Security.
August 3, 200817 yr Top desk is NOT a Free-ware. It is a program that has to be paid for. There are other better alternatives such as WinFlip which consume NO RAM at all. P.S Topdesk consumes at least 10,000K of RAM all times.
August 3, 200817 yr Top desk is NOT a Free-ware. It is a program that has to be paid for. There are other better alternatives such as WinFlip which consume NO RAM at all. P.S Topdesk consumes at least 10,000K of RAM all times.So why don't you post those free alternative apps here?
August 3, 200817 yr Top desk is NOT a Free-ware. It is a program that has to be paid for. There are other better alternatives such as WinFlip which consume NO RAM at all. P.S Topdesk consumes at least 10,000K of RAM all times.OMG 10 megs!!! DIE sucker!!!No really? 10 megs is nothing nowadays.P.S. ALL programs use ram, some are just better at hiding it...
August 3, 200817 yr OMG 10 megs!!! DIE sucker!!!No really? 10 megs is nothing nowadays.P.S. ALL programs use ram, some are just better at hiding it... Yeah, what's 10 megs out of 4 Gigs that we're all using these days
August 4, 200817 yr Yeah, what's 10 megs out of 4 Gigs that we're all using these days There are many programs which consume lesser RAM and imitate the effect better. Some are here1- Shock 3D http://www.docs.kr/2- WinFlip http://winflip.stylekings.de/3- Madotate http://madotate.en.softonic.com/ (For extra special effects)
