Posted October 14, 200718 yr First off I want to thank Kelsenellenelvian for getting me started on INF addons (T.Y. Kelso )OK here is some reading you guys can do if you want to learn to write INF addons/installers, I use them all the time to take a quick peek when I'm lostGuides DownloadINF Doc collectionINF File Sections and DirectivesINF ReferencesToolsInstallWatch and InstallRiteINCTRL5Reg2InfRegShotUseful LinksGosh's WebsiteCreating an INF FileFeel free to ask any quetstion or post more usefull links for other usefull inf tutorials you think should go here
November 1, 200718 yr The link to the INCTRL5 doesn't work:http://www.devhood.com/tools/tool_details.aspx?tool_id=432Can you please fix itIs this the same version you mentionedInctrl5
June 12, 200817 yr Where can we find OSR guide for inf files in PDF that you use un your videos ricktendo64? It would be fine if I have a printed version, to read in my bed hahaha :wub_anim: Edited June 12, 200817 yr by Kal
August 31, 200916 yr You can add INFs during textmode by adding entries to [HiveInfs.Fresh], [HiveInfs.Upgrade], and/or [HiveInfs.Fresh.RemoteBoot] (You should hopefully be able to figure out the meaning of those) in your TXTSETUP.SIF file. When you do this, the flags for registry entries changes slightly. Here they are.REG_SZ - 0x00000000REG_SZ_NOCLOBBER - 0x00000002REG_DWORD - 0x00010001REG_DWORD_NOCLOBBER - 0x00010003REG_MULTI_SZ - 0x00010000REG_BINARY - 0x00030003 REG_EXPAND_SZ - 0x00020000REG_EXPAND_SZ_NOCLOBBER - 0x00020002REG_NONE - 0x00020001VALUE_NOT_SET - 0x00000010 VALUE_NOT_SET_NOCLOBBER - 0x00000012The "noclobber" alternatives above indicate that if the registry entry already exists, it will not be overwritten. Obviously this is only useful if you're running an Update. On a Fresh install, it probably won't matter if you use a noclobber flag or not; the result is more than likely the same.A couple others that are more rare, and I'm not sure exactly under what conditions they ought to be used:REG_SZ - 0REG_SZ - [empty flag]REG_BINARY - 1
September 1, 200916 yr No problem. I'm working on integrating an offline defrag driver into my Windows XP setup, and I wanted it available during PRESETUP.CMD to instantiate it on next boot so that my ROE installs are applied to a freshly defragged partition. Anyway, to accomplish that I had to learn all of the registry flags for the HiveInf files, and it took me a while to find that info so I figured I'd share it here. Probably too niche for most people, but at least the info can be easily found now. edit-As it turns out, those are all on gosh's website. I spent so much time looking for those. aww. lol. Edited September 1, 200916 yr by Dumpy Dooby
