June 4, 200817 yr This is the Start orb that Appears in vista now in xpthis is my first addon I hope you like it.Well when you install it on live it wouldnt work on first Logon but after you restart it would work.ChageLog25/10/2008(V2Final)*Just Fixed If you changed the orb place then made a new user it would go back to original 24/10/2008(V2Beta)*Fixed Background Problem6/6/2008(V.1.5)*Fixed a small bug*Now when you manul install it wouldn`t appear that page asking for the cab file.MD5: 1E020FD1FDF82C25309225FA5EBFCD7AAnother Edition This one is almost the same as old one except it modify the videos and sounds that are in the last of OOBE and add the Orb with it own sound Just if any one wants it (Thx for Bober for informing me the name of the files to Modifiy)MD5: 15FE58B02A65DFADB8B50FB648DDEF50Attention 1-For source patcher Users Like xptsp Intergate this addon After Patching your Files2-Don`t remove OOBE You can disable it but the last video would work Edited October 26, 200817 yr by DaRk MaDnEsS
June 4, 200817 yr whats the difference between the two? http://www.wincert.net/forum/index.php?showtopic=3413
June 4, 200817 yr Mines a teeny bit smaller and uses an inf file. His doesn't use one...but i think yours first the bmp is not compressedand i put it in the windows directory just not to be in the folder and it may be deleted by accident
October 24, 200817 yr thanks man but zhare not downloadingplease rapidshare or alternative link please
October 24, 200817 yr added another link BTW the last time i tested it on live it didnt run right and replaced the background so a new version might be out soon as i hope to fix the problem NightWolfhis might work
October 24, 200817 yr added another link BTW the last time i tested it on live it didnt run right and replaced the background so a new version might be out soon as i hope to fix the problem NightWolfhis might worki hope so. a lot of people seemed to have issues with all the ones out there http://www.ryanvm.net/forum/viewtopic.php?t=3480i even directed them to this one b/c i thought it still worked
October 24, 200817 yr i hope so. a lot of people seemed to have issues with all the ones out there http://www.ryanvm.net/forum/viewtopic.php?t=3480i even directed them to this one b/c i thought it still worked well default install works fine i`m trying to fix the Background problem i got a fix but it`s a big one it depends on installing the orb after windows installation so it would run after the second restart but not tested yet so couple of testes and i might fix it
October 24, 200817 yr Added a Beta Version which Should be Working well i tested it fast and it worked Plz If any problem i`m Glad to helpEdit:A Silent Update and beta word is removed Edited October 25, 200817 yr by DaRk MaDnEsS
October 25, 200817 yr Added a Beta Version which Should be Working well i tested it fast and it worked Plz If any problem i`m Glad to helpEdit:A Silent Update and beta word is removedmany thanks man :sweatingbullets:
October 25, 200817 yr Hi, DaRk MaDnEsSI am one of the people that have been having issues with the orb.ccl0 PM'd me about this one so I gave it a try.I have tried it a few times with Virtualbox and am glad to say it worked perfectly.I would like to thank you for all your hard work in making this work.Regards, Brian.
October 25, 200817 yr Hi, DaRk MaDnEsSI am one of the people that have been having issues with the orb.ccl0 PM'd me about this one so I gave it a try.I have tried it a few times with Virtualbox and am glad to say it worked perfectly.I would like to thank you for all your hard work in making this work.Regards, Brian.well :giveheart: thx for your own replay and testswell this addon was having some serious problem with most of people <<<even mei hope soon i fix that first logon problem without having the background changes(But until now no hopes),thx for your replay and thx ccl0 for your PM Edited January 30, 201313 yr by DaRk MaDnEsS
October 26, 200817 yr Updated!Added Another Edition that Would help in using the video that appear with oobe and replace it with orb Have a Nice Day
November 3, 200817 yr Nice workwould you have a look at doing one for driverpack installation the other one I have tried keeps the backgound instead of your default wallpaper I have tried the fixes for that but have had no luck So if you have time and are interested in doing this I know i will appreciate it and I am sure many others would too Thanks
November 4, 200817 yr Nice workwould you have a look at doing one for driverpack installation the other one I have tried keeps the backgound instead of your default wallpaper I have tried the fixes for that but have had no luck So if you have time and are interested in doing this I know i will appreciate it and I am sure many others would too Thankswell i would try just fixed my own computer so couple of days untill i get back into work i already got an idea that might help but if you don`t mind waiting is all what i can say and thx
December 4, 200817 yr http://www.mediafire.com/?ntmmz1znyrmhttp://www.mediafire.com/?mqyzo2mgom0why.two file..are two file add nlite? Edited December 4, 200817 yr by ss_tekin
December 4, 200817 yr http://www.mediafire.com/?ntmmz1znyrmhttp://www.mediafire.com/?mqyzo2mgom0why.two file..are two file add nlite?no the two files are almost the same the second one replace the start video and sound in OOBE with an orb video + Sound and the other is only the orb that is all i hope you get it and if any problem i`m here
December 4, 200817 yr http://www.mediafire.com/?ntmmz1znyrmhttp://www.mediafire.com/?mqyzo2mgom0why.two file..are two file add nlite?I've tried to explain details here: http://www.wincert.net/forum/index.php?s=&...ost&p=37657Hope its all clear.And DaRk MaDnEsS, this addon works as expected (ahem perfect ) on a turkish windows xp sp3 system. Tested several times with lots of addons. I've had an addon which does same thing but never released it. Your's do the job well then no need to release a second one You're goin very well in real addon making. Like your work & watching all your addons :thumbsup_anim: Cheers
December 28, 200817 yr Ive been using a similar addon... and when I use a 1024 or 800 dimension wall.. it cuts off some of itJust wonder whyPS.. ppl who problems with the wallpaper being same as this when windows, I know of a regtweak that solves that Edited December 28, 200817 yr by wolfsoul
December 28, 200817 yr ppl who problems with the wallpaper being same as this when windows, I know of a regtweak that solves thatWhy not post it then. Stop teasing us.
