[Finished] Building New System
Well Hello WinCerters!
after all this time (about a year ago i started to say i'm going to build myself a computer or get one pre built)
and now i have started to build myself a new one!
if you have not had a look at 'My Specs' this week. i have put up what its going to be once its built.
I'll Be adding Pictures later this day..
Here is what its looking like. :)
[Desktop Antec Nine Hundred Main Computer] BUILDING NOW!!
Case: Antec Nine Hundred <Got!
OS: Microsoft Windows Vista Ultimate SP1 64-Bit OS <Waiting... Going to use Microsoft Windows 7 64-bit untill I get Vista :)
MoBo: Asus P5Q-E <Got!
CPU: Intel Core 2 Quad Q9550 / 2.83 GHz ( 1333 MHz ) <Waiting... using a intel pentium dual-core 2.50GHz 800MHz FSB
Memory: Corsair 4 GB (2 x 2 GB) PC2-6400 DDR2 800MHz 5-5-5-15 <Coming Soon...
Graphics: Xpertvision 256MB GeForce 8600GT <Got! (This is just so i can run my computer... will upgrade on my birthday ;))
PSU: OCZ StealthXStream 600 Watt <Got!
HDD#1 Samsung Spinpoint 500GB 7200RPM 16MB SATA300 <Waiting
HDD#2 Samsung Spinpoint 500GB 7200RPM 16MB SATA300 <Waiting
Dual Screen
Screen #1: Asus 22 " VH226H Black Widescreen 2ms, 3000:1,1920x1080 with Intergrated speakers <Waiting...
Screen #2: 20" Dell SP2009W 20-Inch Widescreen Flat Panel Monitor With Webcam 1680 X 1050 <Got!
I'll be adding another 4GB so I will be up to 8GB.
the MoBo can go up to 16GB.
all the stuff that says Coming soon... hopefuly will be here next week or the week after.
Over Time I'll Will Be Upgrading My System. the Graphics card i will change first...
if you have anythink that i should add later on this year.. please do say! :)
Edited by snakecracker
Nice system, but if I were you, I'd wait for a couple of months and would probably buy a new MBO for iCore7 processors, along with the new Intel processor. But, I'm not sure what will be the price range for the
new processors.
i would love to have that!
i might have that on my next build... (could be for next xmas...?) or over this year...?
Here are some pictures of the Case and MoBo.
If your building a computer i would say to get this case.
its not too big nor too small it can fit most ATX motherboards.
or if you want a bigger case with more fans and so on..
i'll say for you to get the Antec Twelve Hundred
Looking good. I dont like the case to much, but that is me. Good, you got the rite board. Some boards have the PCI-E slots that go over the SATA ports, and over the RAM slots. One thing you should get is a new heatsink, the ones on the Q6600-9300 arnt to great.
- Shadow
- Shadow
I was thinking of getting a new heatsink, seen some really good ones :)
I like the Zalman make.
I don't really like some of the Coolermaster....
lol this is weird i'm a computer technician and stuff.
but this is my first computer build :)
and my system does not work.... :(
well i have got everything i need.
and well nothing will show on my screen...?
i'm not sure if its the graphics card or something else...? :(
the stuff i have in my system now is:
Intel Celeron D 2.66GHz
Asus P5Q-E
nVidia GeForce 8600GT 256MB DDR3
Corsair XMS2 4GB DDR2
OCZ 600W Stealth X Stream
Seagate 160GB HDD SATA
<Unknown> DVD-RW IDE Drive.
When i turn on my comp it starts up with no BIOS Beeps and nothing comes up on any of the 2 monitors?
everything inside is running but nothing comes up...
if you need more info tell me what to look for.
thanks for your help.
EDIT: Keyboard does not light up as it does on my other comp..
EDIT2: MoBo is crossfireX support... will nVidia work (just by itself not on SLI?)
EDIT3: CPU FSB is 533MHz. This is the problem. right? It is the CPU
  • 7 months later...
try resetting the cmos and re-boot...
when i got my motherboard i had same problem.. everytime i started it up i had black screen..
and had to update the bios. then all worked out great..
Edited by dude-uk
It was the CPU the FSB was 533MHz the mobo says 800MHz plus. So i had to buy a new one for my system to run.
