[Solved] Funny bug in 1501_test16
Hi
I´ve just tested 1501_test16.
The bug with "HOSTS" has changed with funny result.
After Setup has finished there is a folder "%Systemdrive%\windows\system32\drivers\etc\"
with the added "HOSTS" in it on Drive C:!
Sorry, its not solved.
Edited by wela
Found a little bug in 150-1_test4 All in One Integrator - Advanced - Files.
I was not able to add "Hosts" File.
Trying to save this "Save to: %SystemDrive%\Windows\System32\drivers\etc\HOSTS" the App shows the Message "Add a File name and Extension to Save to Path".
With 140xx this Problem did not exist.
The above was the first issue i reported.
Today I made a Test with 1501_Test16 and Win7 SP1 Pro x86 german. All went fine. With the resulting iso i started installing in a VM.
And as I said in first post my "Hosts" File is not in C:\Windows\System32\drivers\etc\" after Setup has finished. Its in a Folderstructure extra on C:\ and the structure is named "%SystemDrive%\Windows\System32\drivers\etc\".
I add Session ini from 140_x and 1501_test16. With 140_x adding a "Hosts" works without Problems.
I´m sorry but screenshots are not possible. I deleted all for a next testrun.
Last Sessions.zip
Edited by wela
