October 27, 201214 yr t20 now available.test 20 doesn't integrate any of my addons, not even one. Adoons are ok and worked fine with previous builds (15-19)it says like this below, for every addon added;Description: Some addons could not be added. For more information, click '>> Details'.Exception:Exception:This does not seem to be a valid addon or it may have been corrupted.[C:\Users\*******\Dareckibmw_7-Zip_9.20_x86_Windows7_AddOn.wa
October 27, 201214 yr Please make sure to make a new thread next time. If you click >>Details, it will tell you why it couldn't be added.
October 27, 201214 yr I confirm the issue!No AddOn showed under AddOn-Tab, no errors.With Test19 works fine
October 27, 201214 yr but what does it say under >> Details?Is your question for me too?If yes, I don't get the error-box like @dareckibmw, the AddOn-Tab is simply empty. Edited October 27, 201214 yr by Thiersee
October 27, 201214 yr During loading presets WinToolkit says (very quickly!) for AddOn "Noname (Addon)"
October 28, 201213 yr AddOn-issue again present in Test25 .I'll try now integration/installation (VM) with Test24B; i'll back in two hours.
October 28, 201213 yr For me the issue is gone with test 25. I mean the adding addons to the list part. Also going to make a full integration, and come back with the results.
October 28, 201213 yr I'm getting crazy with this issue !I don't know why and how, but Test19 & Test 24B are loading AddOn, in between and above no AddOn loaded; if try to load any AddOn, no matter wich, error like in Post #6Working OS Win7 x64, the same to be integrated.
October 28, 201213 yr Lego, maybe the decompress 7z x86 tool in the latest test 25 (and 26, 27, 28 probably) isn't compatible with a x64 OS?LE: Once again, for me everything is fine, however my ''environment'' is a x86 OS, unlike Thiersee's x64. Edited October 28, 201213 yr by RicaNeaga
October 29, 201213 yr I'm on x64 and it works fine. When you say no addon loaded, do you mean in the list or into the image itself after your press start?
October 29, 201213 yr I think both: if I try to load an AddOn --- error like Post #6.My .INI-file ist always the same; v24 shows the add-ons.I will try a run now, my be they will be integrated, even if they haven't be shown.
October 29, 201213 yr For me (x86 environment) test 31 is ok - it loads addons. Waiting for Thiersee, then going to use it for a full integration.
October 29, 201213 yr Try test 31 please Seems to work, just integrating.Behavior ist same as in Test24: Loading Presets 90sec against 15sec of Test25-Test30 and no (empty) folder left in WinToolkit_Temp (one for each Update).Just a little "strange" behavior in Test30: IE9-Language Pack has gone red. Edited October 29, 201213 yr by Thiersee
October 29, 201213 yr For me (x86 environment) test 31 is ok - it loads addons. Waiting for Thiersee, then going to use it for a full integration. Integration completed, I make now an ISO and install in VM; I'll back in 1 hour.
October 29, 201213 yr Behavior ist same as in Test24: Loading Presets 90sec against 15sec of Test25-Test30Depends on when you made that preset - on what build, Lego made significant changes over the last year to its app. Maybe if you could start anew / fresh, and make a new preset with test 31 (strating from 0 / no preset loading / introducing the ''setings'' once again), and try to load it again with build 31, then things maybe will be ok.
October 29, 201213 yr Nope, Thiersee is right, it's the loading of updates in the AIO list to blame. In v31, is MUCH slower. So probably Thiersee has in its preset also his updates, so that's why his preset is slower.Thiersee, so nevermind / ignore my previous post, with making the preset once again.
