During Installation in Dos mode various files are missing in Xp Pro SP3
i used the clean xp sp3 source for slipstreaming i dont know which addon or update is causing waste 24 hrs and no progress so far.
found some bugs and removed the bugging addons and now i dont understand which one has the problem please guy help.
the addon bug is dont understand
i have removed these addons i thought i was readding same and same thing again and again
Microsoft_VC+AIO_Runtimes_2.7_AddOn
Microsoft_Legacy_VB+VC_Rtn_2.1_AddOn
qfe sp3 i think has thoses
these also are in qfe sp3
OnePiece_Windows_Update_v7.6.7600.257_True_AddOn_ENU_32D04AE29F1CAECE8D61497E02F889EB
OnePiece_Microsoft_Update_v7.6.7600.257_FULL_True_AddOn_ENU_34AED381C83DF7D0CC3068F7BC015529
i never have any missing files issue before.
all the last ini's i am post for fixing the bug during installation in gui mode almost addon failed to installed error was access denied.
guys can you provide how to test this on vm i mean what programs testing method do have in mind to out that it clean or error free iso like the one used msdn + lots of addons tweaks and all updates till 10-10-12.
please test way methods how to benchmark this iso to the fullest i going to install this one for my pc because in vbox not every thingd possible like quick heal total security cant be installed in vm enviroment.
please provide supportive tools programs anything you name it will for the betterment of my skills on making error free iso of lots of addons
Last Session.ini
post-35082-0-56318400-1351627030_thumb.j
post-35082-0-79720600-1351627330_thumb.j
Last Session (2012.10.30-19.02.04).ini
Last Session (2012.10.30-17.58.33).ini
Last Session (2012.10.30-10.26.38).ini
Edited by Kelsenellenelvian
- Use short path without spaces in it: C:\XP is a good one. Even better use an other hard drive: D:\XP
- Use update pack instead of integrating updates one by one.
- Use RVMi to integrate update pack, then after use nLite to integrate AddOns and tweaks.
- Try to integrate less addons, like half less.
Edited by mooms
U are running on a Win7 host while running nlite? Just a thought... I think this is one of the issue.
Exact problem, I don't know
Hers my take:
Running nLite under Vista can cause many various issues. (Some of which resemble the ones you post here.)
You seen to be having issues that can be caused by having a av\malware app running while nliteing also.
nLiteing the SAME source more than once is a HUGE issue that can cause MANY issues.
Also do you realize nearly ALL of those addons are designed to be used on a SP3 source?
Thus they may be referring to files and\or routines that don't exist in a sp2 source.
en_windows_xp_professional_with_service_pack_3_x86_cd_vl_x14-73974
MD5 5bf476e2fc445b8d06b3c2a6091fe3aa
MSDN Original Untouched ISO SP3
using malwarebytes in vista sp2 used before no issues
Missing Files
Mu.inf
WUWeb.inf
MSVBVM50.dll
wuapi.mui
wuaueng.mui
wuaucpl.dll
wucltui.mui
wups2.dll
i used nino fabbio's all in one update for the latest one and having more missing files than these including them too.
one of the missing files i remember is netaio.exe
few other post them later
i have post all the last.ini's of fresh untouch.iso file i tried 5 different time on fresh untouch iso mentioned above
i never used the same source again and again
Last Session.ini
Edited by Mesiya
Even if this is true, you might try running XP in a VM with all anti-virus temporarily disabled in both the VM and the host system, (disconnect from the internet while you are doing this if you are concerned), and building your new XP build under the XP in the VM just to see if you still have the same problems. If nothing else you could prove us wrong.
WHY do you have 2 dozen or so redundant updates\addons?
i have no idea which are bad could you help
i just want xp with addons so i dont need to install programs one by one
please tell which are dont need to add here the list
Addons List
30/10/2012 02:11 19,372,244 Addon_Java_Runtime_7_update_09.7z
30/10/2012 09:26 29,089,632 Adobe_Flash_AiO_full_AddOn.cab
17/09/2012 22:29 16,057,546 FoxitReader5420901_ENU_Inf_Addon.cab
30/10/2012 09:51 31,264,494 Google_Chrome_SE_22.0.1229.94_AddOn.cab
17/09/2012 23:01 70,883 Image_Resizer_2.1_inf_addon.cab
17/09/2012 23:08 280,653 Kels_Bootvis_CPL_addon_v1.3.37.0.cab
17/09/2012 23:08 139,240 Kels_ClearType_V1.0.0.3_addon.cab
17/09/2012 23:08 7,910 Kels_CMD_anywhere_addon_v1.0.3.CAB
17/09/2012 23:09 4,564,106 Kels_CPLBonus_v12.8.8_addon.rar
17/09/2012 23:09 56,898 Kels_DirectX_CPL_addon_v9.0c.CAB
17/09/2012 23:09 7,265 Kels_FindTarget_addon_v1.1.CAB
17/09/2012 23:09 15,154 Kels_MemTest_v3.6_addon.cab
17/09/2012 23:09 119,034 Kels_MSConfig_addon_v1.2.rar
17/09/2012 23:10 375,444 Kels_Notepad2_v4.2.25.558_addon.rar
17/09/2012 23:10 207,429 Kels_OpenAL_addon_v1.9.9.CAB
17/09/2012 23:10 38,996 Kels_PowerMenu_v1.5.1_addon_uninstallable.CAB
17/09/2012 23:10 18,150 Kels_QFoldersCPL_v1.01_addon.CAB
17/09/2012 22:49 334,313 Kels_RefreshTools_CPL_addon.CAB
17/09/2012 23:11 660 Kels_RegUnReg_addon_v1.2.cab
17/09/2012 23:06 58,089 Kels_Synesis_Run_v2.0.2.32_addon.CAB
17/09/2012 23:13 79,004 Kels_TweakUI_Addon_v2.10.0.0.cab
17/09/2012 22:44 89,784 Kels_TweakUI_v2.10_CPL_addon_build2.cab
17/09/2012 23:39 5,082,742 Kels_Uber_Addon_v16.5.rar
17/09/2012 23:14 14,781 Kels_VirtualCD_addon_v2.1.rar
19/09/2012 05:54 133,453 Mona_ConfigInspector_Addon.cab
30/10/2012 08:57 10,471,826
OnePiece_Haozip_v2.6.8438_AddOn_INTL_1257E78666C2014B193C07D72E98807F.cab
01/05/2012 19:18 122,024
OnePiece_Unlocker_v1.9.1_AddOn_INTL_DBB2473169D7FC710646E2C093EF98E9.cab
30/10/2012 08:55 3,039,541
OnePiece_WinRar_v4.1.0_AddOn_ENU_9AD9DDF68163E468C3C595BA8CD3A36D.cab
17/09/2012 22:39 155,335 OpenWith_Enhanced_1.05_inf_addon.cab
01/11/2012 06:30 37,603,887 ProgramAddons Adobe Reader 11.0.cab
01/11/2012 06:20 7,807,525 ProgramAddons Artweaver 3.1.2.cab
01/11/2012 06:23 3,833,202 ProgramAddons Avant Browser 2012 Build 187.cab
30/10/2012 09:54 9,881,922 ProgramAddons BurnAware Free 5.2.cab
01/11/2012 06:19 8,268,682 ProgramAddons BurnAware Free 5.3.cab
30/10/2012 10:07 2,953,787 ProgramAddons CCleaner 3.22.1800.cab
01/11/2012 06:44 6,193,166 ProgramAddons CDrtfe 1.5.cab
01/11/2012 06:50 2,637,858 ProgramAddons Defraggler 2.10.424.cab
01/11/2012 06:15 2,729,615 ProgramAddons Dexpot 1.6.4.cab
30/10/2012 09:44 3,892,629 ProgramAddons doPDF 7.3.387.cab
01/11/2012 06:12 1,500,651 ProgramAddons EMDB 1.61.cab
30/10/2012 10:07 6,756,437 ProgramAddons EssentialPIM Free 5.03.cab
30/10/2012 09:42 18,228,056 ProgramAddons Firefox 16.0.1.cab
01/11/2012 06:19 18,228,526 ProgramAddons Firefox 16.0.2.cab
01/11/2012 06:15 3,355,176 ProgramAddons Foobar 1.1.16.cab
10/09/2012 01:40 3,449,614 ProgramAddons Free Download Manager 3.9.cab
30/10/2012 09:38 6,306,942 ProgramAddons FreeFileSync 5.8.cab
01/11/2012 06:47 1,088,168 ProgramAddons GPU-Z 0.6.4.cab
01/11/2012 06:51 3,370,730 ProgramAddons Hamachi 2.1.0.215.cab
01/11/2012 06:16 16,187,108 ProgramAddons HelpNDoc 3.7.0.456.cab
17/09/2012 20:35 6,097,694 ProgramAddons ImgBurn 2.5.7.0.cab
30/10/2012 09:34 1,877,863 ProgramAddons Inno Setup 5.5.2.cab
01/11/2012 06:14 25,748,231 ProgramAddons K-Lite Codec Pack Mega 9.4.0.cab
17/09/2012 20:38 1,760,321 ProgramAddons KeePass 1.24.cab
01/11/2012 06:59 14,973,897 ProgramAddons MediaMonkey 4.0.6.cab
01/11/2012 06:00 3,177,987 ProgramAddons Mp3tag 2.53.cab
30/10/2012 09:34 3,235,147 ProgramAddons NetSetMan 3.5.0.cab
30/10/2012 09:36 5,669,854 ProgramAddons Notepad++ 6.2.cab
01/11/2012 06:38 19,561,884 ProgramAddons Partition Wizard Home Edition 7.6.cab
01/11/2012 07:01 9,101,887 ProgramAddons PeaZip 4.6.1.cab
17/09/2012 20:35 4,187,553 ProgramAddons PhraseExpress 8.0.154.cab
01/11/2012 06:22 12,667,085 ProgramAddons PicPick 3.1.9.cab
01/11/2012 07:08 27,379,624 ProgramAddons Pidgin 2.10.5.cab
01/11/2012 06:57 9,199,949 ProgramAddons Rainlendar Lite 2.10.cab
01/11/2012 07:08 6,830,298 ProgramAddons Shareaza 2.6.0.0.cab
01/11/2012 06:57 18,302,427 ProgramAddons Skype 5.10.32.116.cab
30/10/2012 09:52 16,734,507 ProgramAddons SMPlayer 0.8.1.cab
17/09/2012 20:34 2,126,631 ProgramAddons SpeedFan 4.47.cab
30/10/2012 09:32 1,950,033 ProgramAddons TagScanner 5.1.622.cab
01/11/2012 05:57 11,686,574 ProgramAddons Task Coach 1.3.20.cab
01/11/2012 06:04 18,723,356 ProgramAddons Thunderbird 16.0.2.cab
17/09/2012 20:33 1,587,476 ProgramAddons ToDoList 6.5.6.cab
01/11/2012 06:19 488,165 ProgramAddons UltraDefrag 5.1.0.cab
30/10/2012 09:38 22,869,959 ProgramAddons VLC 2.0.4.cab
01/11/2012 07:07 1,472,751 ProgramAddons WinRAR 4.20.cab
01/11/2012 06:06 2,423,204 ProgramAddons XnView 1.99.5.cab
01/11/2012 05:28 1,094,480 Ricks_7-Zip9.27a_Intl_defaddon.7z
17/09/2012 23:05 2,130,151 ROE_SageThumbs20015_addon.cab
30/10/2012 02:11 2,424,868 ROE_uTorrent_addon_3.2.1B28025.cab
17/09/2012 23:04 108,004 RunWithParameters171_inf_addon.cab
30/10/2012 10:00 4,986,156 TeamViewer7Free7013989_addon.cab
update through wget from http://xdot.tk/updates.html
20/10/2012 01:55 288 Kernel-Mode.Drivers-reg-entry.cab
09/09/2012 15:34 119,726 rvkroots.cab
15/06/2010 22:36 552,832 WindowsXP-KB2115168-x86-ENU.exe
07/07/2010 14:14 641,920 WindowsXP-KB2124261-x86-ENU.exe
15/06/2010 22:36 745,344 WindowsXP-KB2229593-x86-ENU.exe
27/07/2010 12:44 600,960 WindowsXP-KB2290570-x86-ENU.exe
24/08/2010 00:07 1,094,528 WindowsXP-KB2296011-x86-ENU.exe
07/09/2010 16:58 706,432 WindowsXP-KB2345886-x86-ENU.exe
17/08/2010 20:03 516,992 WindowsXP-KB2347290-x86-ENU.exe
16/08/2010 14:43 792,960 WindowsXP-KB2360937-x86-ENU.exe
18/09/2010 14:05 1,444,720 WindowsXP-KB2387149-x86-ENU.exe
10/12/2010 18:27 2,508,672 WindowsXP-KB2393802-x86-ENU.exe
09/11/2010 20:59 1,038,208 WindowsXP-KB2419632-x86-ENU.exe
20/10/2010 18:22 514,944 WindowsXP-KB2423089-x86-ENU.exe
04/11/2010 00:04 515,456 WindowsXP-KB2440591-x86-ENU.exe
19/11/2010 10:51 524,160 WindowsXP-KB2443105-x86-ENU.exe
01/03/2011 10:00 750,976 WindowsXP-KB2476490-x86-ENU.exe
20/12/2010 22:48 830,336 WindowsXP-KB2478960-x86-ENU.exe
22/12/2010 18:07 637,312 WindowsXP-KB2478971-x86-ENU.exe
09/02/2011 19:24 679,808 WindowsXP-KB2479943-x86-ENU.exe
02/02/2011 13:26 1,618,304 WindowsXP-KB2481109-x86-ENU.exe
21/01/2011 20:50 3,171,200 WindowsXP-KB2483185-x86-ENU.exe
22/12/2010 00:55 620,416 WindowsXP-KB2485663-x86-ENU.exe
11/02/2011 20:15 568,704 WindowsXP-KB2491683-x86-ENU.exe
08/02/2011 19:09 959,872 WindowsXP-KB2506212-x86-ENU.exe
16/02/2011 12:21 654,720 WindowsXP-KB2507618-x86-ENU.exe
18/02/2011 17:25 664,960 WindowsXP-KB2508429-x86-ENU.exe
03/03/2011 12:24 1,179,520 WindowsXP-KB2509553-x86-ENU.exe
04/03/2011 12:21 864,640 WindowsXP-KB2510581-x86-ENU.exe
21/04/2011 19:45 547,200 WindowsXP-KB2535512-x86-ENU.exe
15/07/2011 20:17 719,232 WindowsXP-KB2536276-v2-x86-ENU.exe
30/04/2011 00:28 807,808 WindowsXP-KB2544521-x86-ENU.exe
10/10/2011 19:52 802,176 WindowsXP-KB2544893-v2-x86-ENU.exe
26/09/2011 23:52 762,664 WindowsXP-KB2564958-X86-ENU.exe
08/07/2011 20:32 501,120 WindowsXP-KB2566454-x86-ENU.exe
02/08/2011 22:07 496,000 WindowsXP-KB2570947-x86-ENU.exe
20/11/2011 11:45 520,576 WindowsXP-KB2584146-x86-ENU.exe
16/11/2011 19:49 737,664 WindowsXP-KB2585542-x86-ENU.exe
18/08/2011 11:43 566,656 WindowsXP-KB2592799-x86-ENU.exe
14/10/2011 20:19 579,456 WindowsXP-KB2598479-x86-ENU.exe
03/11/2011 23:39 496,512 WindowsXP-KB2603381-x86-ENU.exe
18/10/2011 16:40 571,264 WindowsXP-KB2619339-x86-ENU.exe
28/10/2011 11:04 510,848 WindowsXP-KB2620712-x86-ENU.exe
01/11/2011 21:39 1,057,152 WindowsXP-KB2624667-x86-ENU.exe
03/11/2011 21:08 1,169,792 WindowsXP-KB2631813-x86-ENU.exe
26/11/2011 03:22 634,240 WindowsXP-KB2646524-x86-ENU.exe
29/02/2012 19:36 648,064 WindowsXP-KB2653956-x86-ENU.exe
04/06/2012 09:56 582,616 WindowsXP-KB2655992-x86-ENU.exe
09/02/2012 21:18 1,310,592 WindowsXP-KB2659262-x86-ENU.exe
30/08/2012 12:04 768,016 WindowsXP-KB2661254-v2-x86-ENU.exe
12/01/2012 00:35 497,024 WindowsXP-KB2661637-x86-ENU.exe
19/04/2012 17:46 499,456 WindowsXP-KB2686509-x86-ENU.exe
08/06/2012 20:25 3,039,744 WindowsXP-KB2691442-x86-ENU.exe
28/05/2012 23:40 920,832 WindowsXP-KB2698365-x86-ENU.exe
12/09/2012 18:47 686,608 WindowsXP-KB2705219-v2-x86-ENU.exe
14/05/2012 14:46 657,664 WindowsXP-KB2712808-x86-ENU.exe
05/06/2012 21:21 1,589,208 WindowsXP-KB2719985-x86-ENU.exe
12/09/2012 16:40 572,944 WindowsXP-KB2723135-v2-x86-ENU.exe
23/08/2012 12:21 2,275,856 WindowsXP-KB2724197-x86-ENU.exe
13/09/2012 20:01 1,468,464 WindowsXP-KB2731847-v2-x86-ENU.exe
23/08/2012 02:56 510,992 WindowsXP-KB2736233-x86-ENU.exe
31/08/2012 03:06 3,955,728 WindowsXP-KB2744842-x86-ENU.exe
24/08/2012 19:30 585,232 WindowsXP-KB2749655-x86-ENU.exe
13/09/2012 21:39 524,328 WindowsXP-KB2756822-x86-ENU.exe
26/06/2009 01:21 1,131,384 WindowsXP-KB892130-ENU-x86.exe
18/05/2005 00:30 488,176 WindowsXP-KB898461-x86-ENU.exe
09/09/2012 15:14 367 WindowsXP-KB905474-ENU-x86.cab
02/05/2008 20:42 528,424 WindowsXP-KB946648-x86-ENU.exe
09/05/2008 03:15 559,144 WindowsXP-KB950762-x86-ENU.exe
08/07/2008 02:57 594,984 WindowsXP-KB950974-x86-ENU.exe
17/06/2008 01:27 605,224 WindowsXP-KB951376-v2-x86-ENU.exe
19/06/2008 16:40 1,129,000 WindowsXP-KB951978-x86-ENU.exe
13/06/2008 16:10 1,025,064 WindowsXP-KB952004-x86-ENU.exe
01/05/2008 21:29 657,960 WindowsXP-KB952287-x86-ENU.exe
24/06/2008 22:54 532,520 WindowsXP-KB952954-x86-ENU.exe
28/08/2008 15:44 577,576 WindowsXP-KB953155-x86-ENU.exe
21/11/2009 22:41 1,140,088 WindowsXP-KB955759-x86-ENU.exe
07/03/2009 01:21 4,574,080 WindowsXP-KB956572-x86-ENU.exe
19/06/2009 13:33 2,359,680 WindowsXP-KB956744-x86-ENU.exe
23/10/2008 19:39 639,856 WindowsXP-KB956802-x86-ENU.exe
24/06/2009 03:07 563,576 WindowsXP-KB956844-x86-ENU.exe
21/03/2009 23:41 845,712 WindowsXP-KB959426-x86-ENU.exe
01/07/2009 15:40 559,472 WindowsXP-KB960859-x86-ENU.exe
02/07/2009 21:06 1,416,056 WindowsXP-KB968389-x86-ENU.exe
18/07/2009 00:24 1,062,768 WindowsXP-KB969059-x86-ENU.exe
21/10/2009 12:54 668,016 WindowsXP-KB970430-x86-ENU.exe
22/05/2009 00:29 605,040 WindowsXP-KB970483-x86-ENU.exe
28/07/2009 11:12 3,245,936 WindowsXP-KB971029-x86-ENU.exe
10/06/2009 12:38 561,528 WindowsXP-KB971657-x86-ENU.exe
16/10/2009 00:15 568,688 WindowsXP-KB972270-x86-ENU.exe
18/07/2009 11:04 523,128 WindowsXP-KB973507-x86-ENU.exe
05/08/2009 15:51 569,200 WindowsXP-KB973815-x86-ENU.exe
28/07/2009 10:02 547,192 WindowsXP-KB973869-x86-ENU.exe
21/11/2009 15:55 859,000 WindowsXP-KB973904-x86-ENU.exe
26/08/2009 14:16 605,048 WindowsXP-KB974112-x86-ENU.exe
12/10/2009 20:17 609,648 WindowsXP-KB974318-x86-ENU.exe
13/10/2009 17:25 596,336 WindowsXP-KB974392-x86-ENU.exe
05/09/2009 03:35 521,584 WindowsXP-KB974571-x86-ENU.exe
01/09/2009 20:47 657,272 WindowsXP-KB975025-x86-ENU.exe
27/04/2012 21:57 61,414 WindowsXP-KB975254-x86-ENU.cab
11/09/2009 21:16 750,456 WindowsXP-KB975467-x86-ENU.exe
28/11/2009 00:34 1,053,048 WindowsXP-KB975560-x86-ENU.exe
08/12/2009 18:05 697,720 WindowsXP-KB975713-x86-ENU.exe
06/03/2010 01:20 662,392 WindowsXP-KB976323-x86-ENU.exe
29/01/2010 21:04 681,336 WindowsXP-KB977816-x86-ENU.exe
28/11/2009 00:36 572,792 WindowsXP-KB977914-x86-ENU.exe
12/02/2010 10:51 637,816 WindowsXP-KB978338-x86-ENU.exe
01/02/2010 10:57 1,338,232 WindowsXP-KB978542-x86-ENU.exe
17/12/2009 14:25 633,208 WindowsXP-KB978706-x86-ENU.exe
13/01/2010 20:20 530,296 WindowsXP-KB979309-x86-ENU.exe
05/03/2010 21:27 530,808 WindowsXP-KB979482-x86-ENU.exe
16/07/2010 18:07 1,131,896 WindowsXP-KB979687-x86-ENU.exe
15/07/2010 18:44 663,928 WindowsXP-KB981322-x86-ENU.exe
21/06/2010 20:41 1,730,424 WindowsXP-KB981997-x86-ENU.exe
27/08/2010 14:01 552,824 WindowsXP-KB982132-x86-ENU.exe
17/06/2010 19:58 528,248 WindowsXP-KB982665-x86-ENU.exe
20/10/2012 01:55 2,304,242 WindowsXP-WindowsMedia-KB2378111-x86-ENU.cab
20/10/2012 01:46 1,410,533 WindowsXP-WindowsMedia-KB952069-v2-x86-ENU.cab
20/10/2012 01:47 223,862 WindowsXP-WindowsMedia-KB954155-x86-ENU.cab
20/10/2012 01:50 2,377,842 WindowsXP-WindowsMedia-KB973540-x86-ENU.cab
20/10/2012 01:50 224,126 WindowsXP-WindowsMedia-KB975558-x86-ENU-fix.cab
20/10/2012 01:53 880,488 WindowsXP-WindowsMedia-KB978695-x86-ENU.cab
07/11/2009 01:29 6,156,064 X86-en-windowsxp-kb968930-x86-eng_540d661066953d76a6907b6ee0d1cd4531c1e1c6.exe
these are one piece addons
03/10/2012 16:29 173,660,352 (Nlite only)Ricks_XP_to_MCE05_en.7z
02/05/2012 18:10 634 5er_KB893056_SP3_Addon.7z
02/05/2012 18:19 115,294 5er_WMPLyricsPlugin_v0.4_Addon_v1.0_x86.7z
17/09/2012 00:34 17,096,013 Addon_Microsoft.Net_11SP1_20120612.7z
17/09/2012 00:23 61,512,084 Addon_Microsoft.Net_AIO_ROE_20120612.7z
17/09/2012 23:16 5,803,238 Kels_Runtimes_addon_v8.4.2.rar
02/05/2012 17:57 2,413,354 Microsoft_Legacy_VB+VC_Rtn_2.1_AddOn.7z
18/09/2012 19:07 5,565,096 Microsoft_VC+AIO_Runtimes_2.7_AddOn.cab
02/05/2012 16:52 78,762,321
OnePiece_DirectX_Jun2010_x86_x64_True_AddOn_INTL_2D4D034D7214573DAEC7BAA5344177CA.cab
30/10/2012 08:31 11,717,103
OnePiece_IE8_WinXPSP3_v3.6.0_AddOn_ENU_311BFDE726C0F37968D549F6DF4ABB45.7z
17/09/2012 01:38 17,831,057
OnePiece_Microsoft_Silverlight_v5.1.10411.0_True_AddOn_INTL_5307E275607461A292C19165B1656A12.cab
30/10/2012 08:39 533,872
OnePiece_MSXML_4.0_SP3_v4.30.2114.0_True_AddOn_ENU_888EEE2605516BCE5C38AD6778AF5CA3.7z
01/05/2012 20:21 1,421,448
OnePiece_PlayReadyPC-KB971012v1.3-x86_SvcPack_AddOn_ENU_9B0B88E043FFB1629D3C97A31AB52209.cab
30/10/2012 08:33 703,914
OnePiece_Windows_Genuine_Advantage_Validation_v1.9.42.0_AddOn_(WinNT6.x_Only)_0B3D8672BB4CE5502EEDC08E262025FA.cab
01/05/2012 22:33 16,818,721
OnePiece_Windows_Media_Player_11_True_AddOn_v2.5.0_ENU_E88D736A2C0648113B3D077BD5DF80E3.7z
30/10/2012 02:10 54,564,224 XPSP3_QFE_UpdatePack_20121009.7z
Sorry guys no idea which one to not specially
i have tried nino fabbio one all in one but its buggy
bugs it has are ie 8 is showing proper display while running
reparing through control panel doesn't works always
.net 4 apps are saying that .net is not installed
i tired seatoolsforwindows latest version
sorry for put a big list have no idea except addon list which i know i need.
take your time on this if you have sorry again
recent bug integrating ricks mce addon for nlite using xp antivirus disabled
which addon is not compatible i have used rvm mce addon and works this time it nlite version
i have used rvm version before and now nlite version
md5 03794f284265a84b42fb92c2bff17eb4
sfv 8c56f2a1
md5 2f454b95fdc805cc6c618705616238c1
sfv 366eba48
this time antivirus disable and running xp sp3 os
same iso posted before
there so many iso's available to download non are repair enabled and recovery console enabled.
as you xp get corrupted so easily and frequently that why added so many addons i dont have time install them one by one.
sorry again for this gigantic list and last ini please guy help i have no idea which one are bad i have downloaded from wincert.com and www.winaddons.com/
requested lil and other maker no is making that kind of xp version that why i took charge myself.
without it ill waste tremendous amount of time installing apps one by one there are too many to install one by one
if i knew which one to not add ill kick it our instantly its the six fresh time i am making xp iso and no progress god help me i dont think its easy to make lot of addons and all i have downloaded none made by myself and no idea how to make and if knew it will take to much time to make i counted them total 95 addons i dont think i can handle that much.
sorry guys hoping that you could understand my position
used on same stuff except mce addon this time rvmi compatible created the integreted with no errors then used nlite for repair prompt and tweaks finally used driver pack program for driver integration and made iso from nlite.
now ill this piece of iso vbox further issues
post-35082-0-59558900-1351740895_thumb.j
Last Session.ini
post-35082-0-89896900-1351741899_thumb.j
OK lets get something straight right off. There is a edit button. PLEASE use it when adding new information when no-one has replied previously. MANY posts from the same person (1 or more) right after the other is really bad netiquette.
I am getting from your posts that you may have downloaded a warez package you are running all of this off of. If this is so be aware we have a very strong anti-warez stance here and you can get banned for that.
Now for the redundant addons: (Going off of the last session file you posted.
J:\XP Updates for Nlite\One piece updates\1 Manual One Piece Addons\5er_KB893056_SP3_Addon.7z
J:\XP Updates for Nlite\One piece updates\1 Manual One Piece Addons\Addon_Microsoft.Net_11SP1_20120612.7z
J:\XP Updates for Nlite\One piece updates\1 Manual One Piece Addons\Kels_Runtimes_addon_v8.4.2.rar
J:\XP Updates for Nlite\One piece updates\1 Manual One Piece Addons\OnePiece_Windows_Genuine_Advantage_Validation_v1.9.42.0_AddOn_(WinNT6.x_Only)_0B3D8672BB4CE5502EEDC08E262025FA.cab
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB892130-ENU-x86.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB898461-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB905474-ENU-x86.cab
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB946648-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB950762-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB950974-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB951376-v2-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB951978-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB952004-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB952287-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB952954-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB953155-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB955759-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB956572-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB956744-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB956802-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB956844-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB959426-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB960859-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB968389-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB969059-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB970430-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB970483-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB971029-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB971657-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB972270-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB973507-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB973815-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB973869-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB973904-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB974112-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB974318-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB974392-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB974571-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB975025-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB975254-x86-ENU.cab
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB975467-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB975560-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB975713-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB976323-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB977816-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB977914-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB978338-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB978542-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB978706-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB979309-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB979482-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB979687-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB981322-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB981997-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB982132-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB982665-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2115168-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2124261-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2229593-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2290570-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2296011-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2345886-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2347290-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2360937-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2387149-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2393802-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2419632-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2423089-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2440591-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2443105-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2476490-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2478960-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2478971-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2479943-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2481109-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2483185-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2485663-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2491683-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2506212-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2507618-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2508429-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2509553-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2510581-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2535512-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2536276-v2-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2544521-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2544893-v2-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2564958-X86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2566454-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2570947-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2584146-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2585542-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2592799-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2598479-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2603381-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2619339-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2620712-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2624667-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2631813-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2646524-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2653956-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2655992-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2659262-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2661254-v2-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2661637-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2686509-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2691442-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2698365-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2705219-v2-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2712808-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2719985-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2723135-v2-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2724197-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2731847-v2-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2736233-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2744842-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2749655-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-KB2756822-x86-ENU.exe
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-WindowsMedia-KB952069-v2-x86-ENU.cab
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-WindowsMedia-KB954155-x86-ENU.cab
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-WindowsMedia-KB973540-x86-ENU.cab
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-WindowsMedia-KB975558-x86-ENU-fix.cab
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-WindowsMedia-KB978695-x86-ENU.cab
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\WindowsXP-WindowsMedia-KB2378111-x86-ENU.cab
J:\XP Updates for Nlite\One piece updates\2 UDC-10.09.12\X86-en-windowsxp-kb968930-x86-eng_540d661066953d76a6907b6ee0d1cd4531c1e1c6.exe
J:\XP Updates for Nlite\One piece updates\3 Apps Addons\Kels_Bootvis_CPL_addon_v1.3.37.0.cab
J:\XP Updates for Nlite\One piece updates\3 Apps Addons\Kels_ClearType_V1.0.0.3_addon.cab
J:\XP Updates for Nlite\One piece updates\3 Apps Addons\Kels_CMD_anywhere_addon_v1.0.3.CAB
J:\XP Updates for Nlite\One piece updates\3 Apps Addons\Kels_DirectX_CPL_addon_v9.0c.CAB
J:\XP Updates for Nlite\One piece updates\3 Apps Addons\Kels_FindTarget_addon_v1.1.CAB
J:\XP Updates for Nlite\One piece updates\3 Apps Addons\Kels_MemTest_v3.6_addon.cab
J:\XP Updates for Nlite\One piece updates\3 Apps Addons\Kels_MSConfig_addon_v1.2.rar
J:\XP Updates for Nlite\One piece updates\3 Apps Addons\Kels_Notepad2_v4.2.25.558_addon.rar
J:\XP Updates for Nlite\One piece updates\3 Apps Addons\Kels_RegUnReg_addon_v1.2.cab
J:\XP Updates for Nlite\One piece updates\3 Apps Addons\Kels_Synesis_Run_v2.0.2.32_addon.CAB
J:\XP Updates for Nlite\One piece updates\3 Apps Addons\Kels_TweakUI_Addon_v2.10.0.0.cab
J:\XP Updates for Nlite\One piece updates\3 Apps Addons\Kels_Uber_Addon_v16.5.rar
J:\XP Updates for Nlite\One piece updates\3 Apps Addons\Kels_VirtualCD_addon_v2.1.rar
J:\XP Updates for Nlite\One piece updates\3 Apps Addons\OnePiece_Unlocker_v1.9.1_AddOn_INTL_DBB2473169D7FC710646E2C093EF98E9.cab
J:\XP Updates for Nlite\One piece updates\3 Apps Addons\OpenWith_Enhanced_1.05_inf_addon.cab
J:\XP Updates for Nlite\One piece updates\3 Apps Addons\ProgramAddons WinRAR 4.20.cab
J:\XP Updates for Nlite\One piece updates\3 Apps Addons\RunWithParameters171_inf_addon.cab
Thats 142 redundant, useless or duplicated additions. (No wonder you are having issues??)
And just to be totally clear, Kel, what you are saying is that the OP can totally delete all of the items you listed in the above posts since all of their functions are already included in other items he is including in his build. He will have no loss of function or capability in his build by deleting those items. If he continues to have any problems, he should then post details including his new Last Session.ini, specs on which exact source he used, the operating environment of the machine he used to make his build, and any other details he thinks might be pertinent, and we'll go from there. Personally, I would also suggest he first make a build with NO addons at all and make sure that the OS functions correctly, then add a few addons at a time to his build, testing after each build, until he has his finished solution. I know it's not the way he wants to do it, but it will be a heck of a lot easier to debug any problems that way.
sorry guys which all of the files i have downloaded are warez locate one look i am a newbie and i dont think i will warez at wincert please locate i have added all the addons i know i dont think there a website which provides warez addons i remember.
again sorry guys i dont like to post warez on wincert and i know no help will be provided in this regard
Have you tried Kel's suggestion to delete the specific items that Kel mentioned which are duplicates of other items that you also have in your build? Do that, then post details including your new Last Session.ini, specs on which exact source you used, the operating environment of the machine you used to make your build, and any other details you think might be pertinent, and we'll go from there.
As to all the addons you listed, just because they make an addon, doesn't mean you have to include it in your build. Only include the ones you know you will use. You can always add another app to your running system if you find out later that you need it. Then you can add that app's addon to your next build. But let's get one working build made first before you try to add everything plus the kitchen sink to a build that is not proven yet.
i have rvmi this time and deleted almost all of the suggested one accept few i thought needed i dont know which file to add for rvmi but i adding these two i guess will tell. i have installed the os on vbox and testing it so far no issues
z_datastore.ini
integrator.ini
Yeah considering you still won't listen to me, I'm OUT...
man i am sorry what did i do wrong now i have checked these two i thought were different one is cpl addon i guess
look kel bro i am sorry since last its five time i am slipstreaming every time from fresh start i am not a developer.
u told to clean those i did it just to save my time which i wont get back i am not challenging you skills here just kept those for safe side i searched your two big addon cpl one and uber one and deleted which i found duplicates addons
i cross checked user hiddens qfe update and deleted every single i found duplicate the ones i kept for i didnt understand and found that they were duplicates i thought i gave rough task to you guys of more 150 files to cross check thats why i took this measure.
you people are a team and i am just a alone jerk in karachi no friends and support from anyone i am jobless and no hopes from my country sorry for what i did again.
i am currently testing it in vbox so far no issues will test more untill ill install on physical system
please dont mind what i did i am all alone there no live chat kind of support and you people are not just dealing me you have a complete forum and duties to manage.
you have the right to speak like that.
from all of the forum kel bro you check and told only thank you so much.
i wish i could make a bootable virtual cd rom emulator program boot after bios to install any os just like real cd dvdrom so that way anyone doesnt need to burn and prepare cd dvd usb like we from rufus and various iso or cd dvd recording just waste of time and resources.
imagine a bootable cd dvd virtual drive program which takes control of pc without an os install on it just need to copy the portable program and configure to auto boot any selected iso or known cd dvd format and reboot and install on fly from internal hdd.
i have the idea not enough skill to make one.
i wish someone will make what i think quick and fast without installation
Edited by Mesiya
