So ive used the AIO tool to intergrate a windows gadget, however ive managed to install the gadgets inside of the install.wim itself but since ive saved the changes with the AIO the gadget will also be installed using win toolkit. wich means when windows 8 is installed i got 2 of the same gadgets installed. my question is how can i remove the gadget i intergrated using AIO?
PS. I'm using WinToolkit150-1_Test39
Edited by revoxis
