December 30, 201213 yr Hello, Ive managed to create an addon for VLC using the manual method of compressing and renaming to WA extension, but creating it with the addon maker fails every time. Errors_v1.4.1.4.log from the Logs folder of WinToolkit: Win Toolkit v1.4.1.4Log Encoding: UnicodeWin Toolkit Directory: C:\Windows\System32System Directory: C:\Windows\system32DISM Location: C:\Windows\System32\Dism.exeMicrosoft Windows NT 6.2.9200.0 (en-US)Windows 8 Pro N (32-bit,4)9200.16461.x86fre.win8_gdr.121119-1606fAddons=D:\WinToolkit\addonsfDrivers=D:\WinToolkit\drivers\SMUfGadgets=fSilents=fThemes=fTweaks=fUpdates=D:\WinToolkit\updatesfWallpapers=sAICommands=TruesAVScan=TruesAIOSave=TruesUpdFilter=TruesAIOTIME=42m:57ssPreventSleep=TruesCheckForUpdates=TruesDLogging=TruesFreeRAM=TruesLastDir=D:\WinToolkit\addons\VLC-2.0.5\VLC-2.0.5sLastWIM=D:\WinToolkit\testing\win8\SOURCES\install.wimsPLastWIM=D:\WinToolkit\testing\win8\SOURCES\install.wim|N/A|N/A|N/A|N/AsmCheck=FalsesAIOPM=TruesMountTemp=C:\WinToolkit_Temp\MountsQuickMerge=TruesFormSize=|frmUpdCatalog:750*550|frmWIMManager:760*350|frmAllInOne:1040*744|frmMSUtoCAB:750*400|frmAddonMaker:750*401|frmToolsManager:807*424smVerify=FalsesSolDownload=D:\WinToolkit\testing\Updates\sTransparency=100sTransparencyAll=FalsesWinToolkitDISM=RealTimesWinToolkitExt=RealTimesWinToolkitPRI=RealTimesUploadLogs=TruesLastISO_Folder=D:\WinToolkit\testing\win8sLastISO_ISO=D:\WinToolkit\testing\win8.isosMountLog=TruesWelcomeTab=TruesDownloadTab=TruesToolsTab=TruesRegistryLog=True***********************************Form: Addon Maker (1.4.1.4)(frmAddonMaker)Anti-Virus: FalseVersion: 1.4.1.4Description: Unable to compress fileStatus: C:\Temp\WinToolkit\AddonC\D:\VLC-2.0.5.WAException: The execution has failed due to the bug in the SevenZipSharp.Please report about it to http://sevenzipsharp.codeplex.com/WorkItem/List.aspx, post the release number and attach the archive. at SevenZip.SevenZipBase.ThrowException(CallbackBase handler, Exception[] e) at SevenZip.SevenZipBase.CheckedExecute(Int32 hresult, String message, CallbackBase handler) at SevenZip.SevenZipCompressor.CompressFilesEncrypted(Stream archiveStream, Int32 commonRootLength, String password, String[] fileFullNames) at SevenZip.SevenZipCompressor.CompressDirectory(String directory, Stream archiveStream, String password, String searchPattern, Boolean recursion) at SevenZip.SevenZipCompressor.CompressDirectory(String directory, String archiveName, String password, String searchPattern, Boolean recursion) at SevenZip.SevenZipCompressor.CompressDirectory(String directory, String archiveName) at (Object , String , String ) at A..(Object , String , String ) at A..(String , String , Form )Form History:frmStartup, frmToolsManager, frmAddonMaker, Open Forms:frmStartup, frmAddonMaker, Edited February 6, 201313 yr by Tjuh
December 30, 201213 yr Are you able to upload the WA file please and post exactly what you did to reproduce this bug.
December 30, 201213 yr Author Sure thing, - I first filled out all of the options on the info tab- Selected folder containing the VLC files (downloaded the zip version of VLC),selected Program Files folder destination- Hit save, selected destination of WA file and let it run WA file is only 8 bytes (wtf?): http://www.megafileupload.com/en/file/381793/VLC-2-0-5-WA.html
December 30, 201213 yr Worked fine for me, however *Reaper* has already made this an addon. http://www.wincert.net/forum/topic/8981-vlc-media-player-v2050/ *Reaper* does a lot of good work
December 31, 201213 yr Author Strange tho, maybe it's a Windows 8 thing :S, anyway like I said I managed to make the addon the manual way, so it's no biggie.
February 6, 201313 yr Author This thread can be marked as solved and closed, for I have been able to successfully create a VLC addon with the latest test build.
February 6, 201313 yr Well, you, as the OP, can change the title to [sOLVED] by editing it in the first post. Lego then will move it out of the way if he wishes. Cheers and Regards
