March 4, 201313 yr Hi!I want to be sure about a thing.Mcrip updates contains GDR and LDR updates?So i have to take ALL the 384 updates updates (not addiotional) and add them in Win Toolkit?
March 4, 201313 yr McRip servers contain both GDR and LDR updates. You don't have to do ALL of them, but I always do
March 4, 201313 yr Author McRip servers contain both GDR and LDR updates. You don't have to do ALL of them, but I always do How many hours it takes you to finnish the image?What do you recommand to add from McRip "Additional" folder?
March 4, 201312 yr Author Another question:At the "Integrated" tab at state it says "Install Pending'. This means that the kbxxxx update will be installed during windows instalation or after it?
March 4, 201312 yr Hi, i never really understood why to install LDR.windowsupdate only offers GDR so 99% of the people don't need LDR. I started a new image because i kicked the integration of LDR My old Image took around 6 hours with ~400 updates, its hardly dependingon your computers power and storage speed. Greetz X23 Edited March 4, 201312 yr by x23piracy
