[Solved] Bug in v1.4.1.18 - Silent Installers
I have a huge bug/issue in v1.4.1.18:
ONLY the installers without parameter "Always install" (Prompt for install) have been installed, from the "Always Install" NO ONE!
Of course all silent-installers have been integrated and are present in the folder "WinToolkit_Apps; no errors.
What happened?
Thiersee
Edited by Thiersee
That does not make sense.
May be, but exactly this happens!
I get the prompt list, where I can choose additional programs to install, I can choose single programs (or none); if I press "Start" I get the Installer-Box and in this box stays "Installing 1 of X", where X is the number of selected Programs.
I can now start another installation with no selected "prompt"-programs and a new integration/installation with v1.4.1.16 and report later.
I'm back!
I confirm: v1.4.1.16 works, v1.4.1.18 not; here my Wintoolkit_Apps content
in the WintoolKit-Installer-window stays "0 Auto Installs", it should be (in my case) 22
Thiersee
Edited by Thiersee
Which logs do you need?
I'm integrating now again with v1.4.1.18, tomorrow I do the same with v1.4.1.16 and v1.4.1.15, of course always with a new ISO and the same INI.
Thiersee
Edited by Thiersee
C:\\Windows\\WinToolkit\\RunOnce.log
No such log found, neither under v1.4.1.15 (all silent-installers installed), nor in v1.4.1.18 (no silent-installers installed).
