[Solved] AIO Tool & Wim manager - Applying Unattended from UNC
All works fine if you choose Unattended.xml from Mapped network drive, it will get applied just fine.
But if you choose the very same file via UNC path, it doesnt give you any error, but Unattended.xml doesnt get applied.
So:
Z:\Customization\Unattend\Somekind.xml - Works
\\NAS\Customization\Unattend\Somekind.xml - Doesnt work
Edited by Etz
  • 4 weeks later...
