Thunderbird SFX Maker 5.4
Here is a script that will download Thunderbird in the language/version of your choice and create a switchless installer (and nLite/RVMi AddOn if you still use it).
How-to use:
  • Extract the content of the archive in a work folder.
  • Simply run Thunderbid_SFX_Maker.cmd
You can also edit the file to skip one or more question. See the included Readme file
Thunderbird_SFX_Maker_5.4.zip
SHA1: 3af6498fc4505e75b409eb9b6cf4cbb3209532fb
  • 2 years later...
  • 2 years later...
Hi Thiersee, I just updated it for Thunderbird 60
Version 5.4
What's new:
  • The script is now based on the Firefox maker, hence the same version number
  • Added the x64 and AiO option
  • Added a downloader script (if you just want to download Thunderbird and not make a SFX)
  • 3 months later...
