[Solved] Toolkit 1.4.36.2 (IE11 integration & Silent Installer) doesn't work
Hello. Same problem actually with IE 11 x86 version (french language) : error message is that "IE 11 doesn't seem to be a x86 version" (but it is). I just finish actual integration (other update KB seem to be OK) and will test a previous version of win toolkit and will try to integrate IE 11 and updates.
EDIT: works perfectly with version 1.4.32.5
Edited by rhahgleuhargh
Same here.
During integration configuration under WinToolkit 1.4.36.2, it says "This version of IE does not seem to be for x64".
After integration, I launch a test-install from USB key on a 1st gen Core i7 machine with USB2 ports. RunOnce Installer succeeded with 2 silented exe files (Malicious software removal tool and WinDefender definition) but fails with all .msu files which cannot be integrated in "Updates + Language" tab. During failure, it says installer cannot find files with a Windows HRESULT behind (...I forget it :s )
Source ISO : Official Windows 7 SP1 x64 - French.
All .msu/.exe are in french too.
Hi, but that is no problem.
Only he does nothing after the Windows installation
This comes after the Windows installation no window with the installation procedure, etc.
He just does not install anything.
I testing your software often throughout the day
Edited by bphlpt
Merged posts
