WTK: AIO-Integrator: Little Question...
Hey,
Do the AIO-Integrator move incompatible updates automatically?
Incompatible Updates: Updates they should move to silent installers, else bsod or other errors.
So lets AIO-Integrator make it completely alone or i have to care with handling updates?
Thx for answering.
So if any new updates seem to cause a problem, post your concerns in the "bugs" section as a potential bug.  To help out, try to determine if it is an issue with one or more particular update vs an interaction between updates by at least trying a build with only that one or more particular update that seems to have a problem, and any prerequisites of course, and another build with whatever updates you usually add.  Post a copy of the presets you used and whatever logs are generated, along with details of the OS you were working with and that of your host system.  Further tests with older Win Toolkit versions or other update options you think might shed some light on the situation can only help but are up to your time and ability.  Then see if anyone else is having similar issues.  The more background and details we can provide to Liam, the easier his job will be and the quicker a fix can be found.
