[Solved] 1.4.44.1 - Integration Problem with Driver
Hi Liam,
i will integrate USB 3.0 driver with
this Option: "Integrate USB drivers (boot.wim)"
The Windows Installation from USB with Windows 7 and the USB 3.0 Driver
works, he found USB 3.0 Stick and Drivers and can install Windows correctly.
but, when Windows is starting up, Windows found no USB 3.0!
So when i have on USB the RunOnce installer he dosn't can install the files,
whil the USB 3.0 Drivers are missing.
I must install under Windows the USB 3.0 Drivers manually
Edited by Cartman586
What chipset is that?
So far I havent had any issues with USB3.0 drivers on Asmedia and Renesans chipsets... :g:
I know that some Intel`s are problematic...and you can install those machines only using 2.0 ports.
Edited by Etz
- ASMedia xHCI Host Controller Driver 1.16.15.0 (asmthub3)
- Etron USB3 1.0.0.119 (etronxhci)
- TI xHCI Driver v1.16.4.0 WHQL (tihhub)
- USB3 Win7 3.0.0.33 (iusb3hcs)
- USB3.0 allOS 2.1.39.0 (nusb3hub)
- VIA USB3 xHCI 6.1.7600.4501 (viahub3)
Read the Problem again!
I read the problem, but you didnt specify which particular Chip has that issue...hence I cannot try to reproduce it, if you dont give me any info...
Asmedia 1.16.15.0 works for sure, as I do use it myself to install my Desktop powerhouse...
Edited by Etz
