August 8, 200719 yr hidoes anybody know how to add your own boot screen to xp setup cd. i have used stardocks boot editor to apply a boot screen, now i want to add that boot screen to my xp setup cd, and also the logon screen as well. please help me
August 23, 200718 yr You must be careful when adding boot screen. The file must me compatibile with your Xp version, I know cause there can be found sp1 and these days maybe even sp3 prerelease boot screen. Be careful. And also make a backup before you take any replacments in your root directory. You can also edit startup.ini file latter when you check and see yourself that it's working fine. Startup.ini can be adressed throug sys propertes\advanced\startup and recovery\settings
