November 30, 200718 yr With some skins, the main sections are not made as links so when you right-click them you cant open them in a new tab/window.vs The following themes have this feature or problem:Dark ElectricLuminosi-TABWell the reason I notice this is because i-TAB is the default theme. I have to login to change the theme to browse the forums more comfortably.
November 30, 200718 yr Yes, I'm aware of this problem. Rick also told me about this and I'll have to contact skin makers to see if there's a solution for this issue..Thx for the feedback.
November 30, 200718 yr I guess the reason i-Tab makers think that their skin already has tabs then there is no need for tab browser support
November 30, 200718 yr I'm using "Reflection Blue" skin atm and it also have the same problem. I was going to create a thread about it but I found this thread. I think there is an option in ACP to disable it.
