May 17, 200817 yr HiJust want to know if you got problems after using the bridge for IPB and Joomla from BBPixel? I mean when you upgrading any of Joomla and IPB?Thanks
May 17, 200817 yr I had couple of problems, I don't remember, but I'm not using the bridge anymore anyway..HiJust want to know if you got problems after using the bridge for IPB and Joomla from BBPixel? I mean when you upgrading any of Joomla and IPB?Thanks
May 19, 200817 yr Their members only section has been littered with issues. A lot of people had self replicating members in the database.
May 19, 200817 yr Author Their members only section has been littered with issues. A lot of people had self replicating members in the database.Please more details to follow you correctly my friend.Thanks
May 19, 200817 yr Basically it would take a single user and repeat them in the MySQL database.If you've seen Star Wars ep 2, The Clone Wars... ..it's like that. Imagine an army of 10,000 MGadAllah's in your MySQL database.
May 20, 200817 yr ROFL, yeah one of those updates messed up my SQL ID's. For instance latest member id was 520 and after the update new member had 1041 LOL, off course, no fix for that..Basically it would take a single user and repeat them in the MySQL database.If you've seen Star Wars ep 2, The Clone Wars... ..it's like that. Imagine an army of 10,000 MGadAllah's in your MySQL database.
May 22, 200817 yr Unless you made a database backup before applying the update, which is a good practice.
