February 1, 200916 yr Here s the situation. Computer #1 is connected directly to the printer Computer #2 is networked on a home-file/printer sharing network with computer #1 as the main computer. I have had this working so #2 could print with #1 acting as the printer server. Now however,I can ping #2 from #1 but not the other way. If I disable the firewall in #2 the results are the same. If I disable the firewall in, both I can ping #1 from #2 but I still cannot print from #2. Is this clear and if so what might the problem be?
February 2, 200916 yr If you want to ping #1 from #2 you should allow File and Printer Sharing on computer #1. Actually, the best way is to enable this on both computers in firewall settings.What kind of printer is that. Does it have a network card, did you setup printer permissions properly..Could you please give me more info, so I can investigate...Regards
February 3, 200916 yr Author I have fixed the ping situation. I can now ping #1 from #2. I am still unable to print from #2. I have enabled printer sharing on both computers. I am using Windows firewall I have checked file and printer sharing in the exceptions tab.This is an HP Deskjet 5440 printer.I have been able to print from #2 in the past.I believe I set up printer permission properly, but maybe not. What are the proper steps?I don't believe the printer has a network card. I am using computer #1 as a printer server.
February 3, 200916 yr I have fixed the ping situation. I can now ping #1 from #2. I am still unable to print from #2. I have enabled printer sharing on both computers. I am using Windows firewall I have checked file and printer sharing in the exceptions tab.This is an HP Deskjet 5440 printer.I have been able to print from #2 in the past.I believe I set up printer permission properly, but maybe not. What are the proper steps?I don't believe the printer has a network card. I am using computer #1 as a printer server.Please, right click on the printer and choose properties. Select security tab and post a screenshot here.thx
February 4, 200916 yr Author There is no security tab when I click on properties. here is the screen shot of what I see.
February 4, 200916 yr I see to printers with the same name..Can you make a screenshot of the sharing tab please..
February 5, 200916 yr Author here it is. on the list the first one is Computer #2 and the second is #1 Edited February 5, 200916 yr by Stephen47
