Speedup Internet Explorer 7
Assorted methods to Speedup Internet Explorer 7
Method 1
Before you start take back up of your registry.
Start -> Run -> regedit -> right click to My Computer -> Export and save it.
Save this text in notepad with ".reg" extension! And merge it.
[HKEY_CURRENT_USER\Software\M*cro$oft\Windows\CurrentVersion\Internet Settings]"MaxConnectionsPerServer"=dword:00000010
"MaxConnectionsPer1_0Server"=dword:0000010
Delete the following key
HKEY_LOCAL_MACHINE -> Software -> M*cro$oft=> Windows -> Current Version -> Explorer -> RemoteComputer -> NameSpace
There is two reg keys! Delete this one:
{D6277990-4C6A-11CF-8D87-00AA0O60F5BF}
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\ServiceProvider]"DnsPriority"=dword:00000001
"HostsPriority"=dword:00000001
"LocalPriority"=dword:00000001
"NetbtPriority"=dword:00000001
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters]"ForwardBufferMemory"=dword:00024a00
"NumForwardPackets"=dword:0000024a
"MaxForwardBufferMemory"=dword:00024a00
"MaxNumForwardPackets"=dword:0000024a
If you use modem then do as follows:
Control Panel -> System -> Hardware -> Device Manager -> [modem and modem model] -> Double click on default modem -> Modem -> Maximum port Speed (put on max)
Method 2
Turn off Phishing Filter in IE 7
Click on Tools -> Internet Options -> Advanced
Near the bottom of the list of options, it has a Phishing heading and 3 options. Set it to "Turn off automatic web site checking".
Alternatively you can download and apply IE7 Phishing Filter Speedup Patch. M*cro$oft has released patch for IE7 that speeds up the built-in phishing filter, which otherwise can slow down your web surfing. It can be downloaded from here
http://www.M*cro$oft.com/downloads/details.aspx?FamilyId=EF6EA470-D51C-4BE5-A15B-74430E9E2AD4&displaylang=en
Method 3
Try to launch IE7 without add-ons. It
Try copying the key, and searching the registry for it. Maybe it's located somewhere else? :unsure:
I mean what is applied function if I did merged this Key? that is my point, may be I did not cleared my self quite enough, sorry N1K :(
  • 6 months later...
