VLC Media Player
14,2 MB (14.983.168 Bytes)
1cad7fbbf27615f73b215a6e5d083cbd
Description
VLC media player is a highly portable multimedia player for various audio and video formats (MPEG-1, MPEG-2, MPEG-4, DivX, mp3, ogg, ...) as well as DVDs, VCDs, and various streaming protocols.
It can also be used as a server to stream in unicast or multicast in IPv4 or IPv6 on a high-bandwidth network.
It doesn't need any external codec or program to work.
Version: 0.9.9 fixed
Addon Release Date: JULY 31, 2009
Credit: *MasterSaMMy*
Edited by *Reaper*
Use to be my favourite player as well, but then i switched to Media Player Classic home cinema version, and since then never looked back as VLC.
Thanks for this great addon
tanks MasterSaMMy
but there is something wrong in ur [CopyFolder]
Name=VideoLAN - VLC media player
Creator=MasterSaMMy
Version=0.9.9
Arc=x86!
Description=VLC media player is a highly portable multimedia player for various audio and video formats (MPEG-1, MPEG-2, MPEG-4, DivX, mp3, ogg, ...) as well as DVDs, VCDs, and various streaming protocols.
Website=http://www.videolan.org/
[CopyFolder]
TrueCrypt::Program Files
[CopyFile]
VLC media player.lnk::ProgramData\Microsoft\Windows\Start Menu\Programs\VideoLAN
  • 3 months later...
I am having troubles with this addon (1.01).
When I try to integrate it, it doesnt work, it just keeps saying integrating addon, nothing happening tho.
Other addons just integrate in couple of seconds, but this one took way longer, so I cancelled integration, since nothing was happening.
Yes it does it with random addons... when that happenes go to the temp folder (C:\W7T) and delete the folders inside. or do the addons 1 by 1
Yes it does it with random addons... when that happenes go to the trmp folder (C:\W7T) and delete the folders inside. or do the addons 1 by 1
Ok, lets try that. :D
I tried integrating in groups of 4, and still this one doesnt integrate..
1by1 is awfull lot of work,.
Ok could be a problem with the addon.
I'll take a look in abit.
EDIT: Found the problem i'll fix and upload it till MasterSaMMy comes back.
Ok, thanks!
Here ya go it has intergrated but i have not tested it in VMware. It should work if not tell me right away i'll get on it asap!! :)
size.png14.3MB (15,006,682 Bytes)
post-4451-1205780671.png2AB0E3DD008C7157758071C1BE8EA80D
Edited by snakecracker
size.png14.2MB (14,980,032 Bytes)
post-4451-1205780671.pngCEAFD79DF58C648811A06F5B30B225B9
Will take a look.
Thanks!
snake you missed a line
VideoLAN::Program Files%ProgramFiles%
Thats how W7T puts it now.... You can Put %ProgramFiles% and it will install to Program Files... like normal..
well i think you only need one
not both
not both
not sure myself but it puts it like that all i typed was %ProgramFiles%
Finally forum is back with cool new look. :thumbsup_anim:
But I get this after install:
Thats not how it should be, is it? :P
:sweatingbullets: ok i told Snake but he didn't listen
in task.txt
you would find
remove the %ProgramFiles%
to fix that issue
Hey, sorry guys i've uploaded it with the right settings. (I hope) lol
