XP Vista Pack
by oddbasket
Consists of Vista RTM sound scheme, Aero pointer scheme and all Vista wallpapers 1920x1440 and widescreen 1920x1200.
Aero pointer scheme:
-Without the impractical precision and text select cursors
-Unavailable cursor made with the white parts transparent
-Normal cursors work with 'Enable Pointer Shadow' option
Vista RTM sound scheme:
-Re-encoded for better volume and clarity
-User Account Control sound used for System Notification instead because the latter was annoying
36 Vista Wallpapers:
-29 1920x1440 wallpapers
-7 1920x1200 widescreen wallpapers
Using XP Vista Pack:
After installation,
1. Choose 'Vista RTM' sound scheme in Control Panel.
2. Choose 'Windows Aero' pointer scheme in Control Panel.
3. Choose a Vista wallpaper in Display Properties.
Download XP Vista Pack (14.4mb):
(32bit installer) deviantART
Download (x64 installer)
  • 6 months later...
  • 1 year later...
THANKS
