January 25, 200719 yr I wonder is it possible to change the BIOS password while you're logged in Windows XP?I would really need this tool for my work enviroment..To be exact, I need an option to remotely VIA WLAN set BIOS password on anoter PC if possible.Thx
February 18, 200719 yr It would be different for each mobo manufacturer. So contact the manifacturer of the mobo in question for possible (but unlikly) solution. Edited February 18, 200719 yr by monkey56657
May 30, 200718 yr To change the bios password while you are logged on in XP ?? I never heard of somebody to pull this of !! The only way i know to reset a Bios pass is to remove the MB Battery for 20 sec but this is old news, if anybody can do that pls share how !!! Edited May 30, 200718 yr by d3monh3art
May 31, 200718 yr Author To change the bios password while you are logged on in XP ?? I never heard of somebody to pull this of !! The only way i know to reset a Bios pass is to remove the MB Battery for 20 sec but this is old news, if anybody can do that pls share how !!!It's actually possible with this tool: http://www.pcworld.com/downloads/file/fid,...escription.htmlUnfortunatelly IBM has some special BIOS settings so I couldn't change it..
