VLC Media Player
14.26 MB
0D94DA81B07EA5BB4B1331EA6C3EB256
Description
VLC media player is a highly portable multimedia player for various audio and video formats (MPEG-1, MPEG-2, MPEG-4, DivX, mp3, ogg, ...) as well as DVDs, VCDs, and various streaming protocols.
It can also be used as a server to stream in unicast or multicast in IPv4 or IPv6 on a high-bandwidth network.
It doesn't need any external codec or program to work.
Version: 1.0.1
Platform: x64
Unistallable: Yes
Shortcuts: Same as that in After install version.
Software Release Date:July 29,2009
Addon Release Date: July 31, 2009
Credit: Jatin Beniwal
Edited by *Reaper*
1.0.2 is out, but where can I find original X64 install, dont see it @ their website, or is it in the installer?
Actually there is no x64 source. This is the x86 version. Registry Entries and Program Folders are Different in x64 Architecture for 32 bit programs. Thats why this addon come into presence. Latest Build For Vlc Player is 1.0.3 RC1.
This is the Changelog For 1.0.3 Rc1 over 1.0.2. New addon release is postponed till 1.0.3 Final Build.
#Video outputs:
* Fix video quality when resizing the video on Windows Vista and 7, due to regressions in most popular drivers
* New deinterlacers modules based on yadif and yadif(x2) algorithms
#Decoders:
* Windows version supports now natively the WMA Professional codec, as it didn't work in the packaged version of 1.0.2
* Fix downmixing of particual 4.0 AC-3 audio tracks
#Encoders:
* x264 has profile-limitter, like:
#transcode{vcodec=h264,venc=x264{profile=baseline,level=12}..}
#Input:
* Update for appletrailers lua script
* Fixes on the RAR stream filter
* Fix for E-AC3 in ATSC/TS streams
* Various fixes for v4l and v4l2
#Service discovery:
* New udev module for linux
#Qt4 interface:
* Fixes on the playlist and the stream output panels
#Translations:
* Russian, Korean, Ukrainian, French, Polish, Slovak and Galician updates
Changes From Build 1.0.1 to 1.0.2
# Decoders:
* Native support for WMA Professional, without the use of the Win32 dlls
* Fix issues in subtitles, especially SSA ones
* Various fixes on theora and ogg
# Demuxers:
* Various fixes for EPG support in MPEG-TS demuxer
* Fixes for potential stack overflow in .avi, .mp4 and .asf demuxers
# Access:
* Fixes for v4l2 devices
* Fixes for dvb-c channels-scanning
# Qt Interface:
* Fix some playlist sorting issues
# Mac OS X Interface:
* Fixed a crash when updating VLC
* Fixed a crash related to QTKit when opening video files (10.6 only)
* Added the ability to play 2nd media in sync to the primary item (input-slave)
* Added the "Quit after Playback" feature
# Mac OS X Port:
* The "Delete Preferences" script is now delivered as a Universal Binary
with native code for PowerPC, Intel and Intel 64bit
* Full 64bit runtime compatibility on both Mac OS X 10.5 and 10.6
- no support for Goom and SDL
- limited text rendering support
- This port is still considered as EXPERIMENTAL despite its binary release.
# Encoders:
* MPEG2 transrate stream output removed
* x264 default-values closer to x264.exe defaults.
* x264 rc-behaviour fixes:
- if user defines qp-value, CQP-mode is used
- otherwise if user defines vb=0, CRF-mode is used
- otherwise ABR-mode is used
* x264 set vbv-bufsize/vbv-maxsize better if user hasn't defined these:
- ABR mode set vbv-max-bitrate=bitrate
- vbv-bufsize is bitrate * seconds between keyframes (keyint/fps)
# Playlist:
* Lua scripts for Mpora and Vimeo playback
# Unix builds:
* Various fixes to enable 1.0 to build on Solaris and OpenBSD
# Translations:
* New Kazakh and Croatian translations
* Lithunanian translation is available on Windows
* Galician, Korean, Nepali, Vietnamese, Ukrainian, Brazilian, Arabic and French translation updates
