October 17, 200916 yr Hello guys...I'm new here & i Want to contribute some of my mod...Recently I've reshacked my regedit and replace the folder icon... but unfortunately instead of displaying a properly 32-bit icon it dispalys low quality icon.... just like this:that's make me thinking....there must be a way to make it (regedit) displaying 32-bit icon....And here's what I've got.....to enable 32-bit icon do:Original74 05 BF 01 20[obsolete]use this instead:Normal Process:33 FF 6A 31 47Mirrored process:BF 01 20 00 00New 32 Bit90 90 BF 21 00[obsolete]use this instead:Normal Process:33 FF 6A 31 47Mirrored process:BF 21 20 00 00Note: search for original byte and then replace it with reserved code....But.... what about taskmgr???To make it displaying 32-bit icon in the user tab just do:Original74 05 BB 01 20 [obsolete]use this instead:Normal process33 DB 89 7E 08 43Mirrored process:BB 01 20 00 00New 32 Bit90 90 BB 21 00 [obsolete]Normal process6A 21 89 7E 08 5BMirrored process:BB 21 20 00 00and You'll got this :instead of this:enjoy Dubby 2009...For Outlook NEW!load all comctl32.dll in Winsxs directoryoriginal....7D FC 74 0B 8B 4Dpatch...7D FC 90 90 8B 4Dthen load comctl32.dll in system32 folderoriginal:7D FC 00 74 0B 8B 4Dpatch:7D FC 00 90 90 8B 4DDubby 2011...last update 2012... Edited November 23, 201213 yr by Dubby
November 20, 200916 yr Author Waw, thanks alot Gabee and Ricks.. so sorry for late replying, busy with some assigment..
December 28, 200915 yr note: This is a HEX edit mod of the files. So don't waste your time searching for those strings in the reshacker.btw, thanks for sharing that info. Edited December 28, 200915 yr by mimorqleko
March 3, 201015 yr Author Uhm.... you'll gonna neeed hex editor to do that patch..., for example just google for hex editor... you'll find alot of hex editor available.... then copy your regedit and taskmgr to another location... find those hex code occurance... then replace with reversed code above... save it.... and if you want to replace the system file use replacer (google it) for the easiest way.. Hope this help... By the way sorry for late reply.... just log in back in a moment....And sorry for my english....
March 5, 201015 yr thank,i make ok but install windows cannot copy regedit.exe Edited March 5, 201015 yr by ngoclinhdtdd
March 12, 201015 yr Dubby,can you for battery laptop view in wpdshext.dll 32 bit make.thank friend Edited March 14, 201015 yr by ngoclinhdtdd
March 28, 201015 yr Author Dubby,can you for battery laptop view in wpdshext.dll 32 bit make.thank friendsorry .... but I can't found the file.... are you sure that the the name is "wpdshext.dll".... :questionmark: or just upload your file... and let me see what can I do for you...
March 29, 201015 yr it`s batmeter.dll and can you for outlook make in msoeres.dll.sorry, my bad english.here it`s link file :http://www.mediafire.com/?ggrwnjmmlz1
May 1, 201213 yr Author Updated with more optimized patch and more support,also I would thanks to Ricktendo64 for updating my patch above...
November 1, 201213 yr can you fix vista taskmgr here original vista taskmgr http://www.sendspace.com/file/6jrpeyplease help... Edited November 1, 201213 yr by xsallyty
November 22, 201213 yr Author sorry for taking so long..anyway here it is: for vista's taskmgr above:original:6A EC 33 DB 56 89 77 08 43patched:6A EC 56 6A 21 89 77 08 5B
November 22, 201213 yr So the edits for Regedit and TaskMgr are obsolete, and this thread now only applies to Outlook (And Vista's TaskMgr)?Cheers and Regards
November 23, 201213 yr Author I'm sorry if I'm not made myself clear, the #1 post still applied to XP's regedit and taskmgr also outlook and possibly another XP programs which ultilize ImageList_LoadImage...while the #19 post only applied to vista ones, which file is provided by xsallyty..Many thanks Rick.. I also notice that several picture have gone.. I'll update it as soon as I can...
June 18, 201411 yr YEAH! You're the men, Dubby! :prop:He wake up a morning. Think about Regedit, and without looking it, brandished his wand with a hand, and rocks the f***ing regedit. But, i couln'd make it work. :ranting: I tried 5 hex editors. :notworking: I'm interesed in the Regedit only. Please! Would you please make screenshots of the stpe by step. Please Dubby. :please: (All apologies for my english)
July 17, 201411 yr Author whoaa... hello...the steps should be generic for all hex editor...the only required feature is "search and replace"....make sure to hit save when done editting....to be safe, make a copy of regedit into somewhere else.. then edit the copied ones... not the original...also after editting you'll need to replace the icon with the new one....
