January 16, 201115 yr First I have want to thank the creators of this app. I have built a few unattended installs about 1 year ago and it was flawless. Recently I went to update my disk and make some changes. I'm using the same build O/S (en_windows_7_ultimate_x86_dvd_x15-65921.iso) and the BETA WTtools (W7T085-14B and have tried W7T080-37F). I get errors every time I try to install after modifying the wim. I have trouble shot from just adding 1 addon to just 1 silent install to removing the autounattend.xml. I'm lost. Errors I get are:config_initialization_failedError code 0
January 16, 201115 yr Do you have a print screen? which addon/silent install was it? At which stage of the install does it give the error?Have you tried without the unattended.xml? Edited January 16, 201115 yr by Legolash2o
January 16, 201115 yr Author Do you have a print screen? which addon/silent install was it? At which stage of the install does it give the error?Have you tried without the unattended.xml?Sorry no print screen. Different addons I have tested (Reaper). Silent installs are simple Acrobat or other msi using /qb swith. I always get the error right after first restart after Expanding files 100%, installing features, Installing updates, restart, get ti windows 7 boot screen then error.
January 16, 201115 yr Ok, please try the latest version, i released it today (v15) If still no success please tell me an addon you used.
January 16, 201115 yr Author Same errorI attached log files. I tried with and without autounatendedLogs.rar
January 17, 201115 yr Author Ok, please try the latest version, i released it today (v15) If still no success please tell me an addon you used.When using W7T0-6-0-17 I have no issues but I loose all the new features. Any suggestions?
January 17, 201115 yr Author Ok, please try the latest version, i released it today (v15) If still no success please tell me an addon you used.BUMP
January 17, 201115 yr Author I saw, i will look into it. I've got quite a few bugs to fix. :thumbsup_anim:
January 23, 201114 yr That's a lot of addons HiJackThis7-ZipAdobe Flash Player 10 ActiveX PluginAdobe Flash Player 10 PluginAdobe Shockwave PlayerAutorunsCCleanerOpen Command Prompt Shell ExtensionCore TempCPU-ZDAMN NFO ViewerDefragglerDVD DecrypterGPU-ZHashCheck Shell ExtensionHDTuneHWMonitorImage Resizer Powertoy Clone For WindowsImgBurnIP Configuration ManagerJava Runtime EnvironmentK-Lite Mega Codec PackMalwarebytes' Anti-MalwareMozilla FirefoxNFOPadNotepad2MiniTool Partition Wizard Home EditionPC WizardRegShotResource HackerRunAlyzerUniversal ExtractorUniversal TCPIP Patcher x86uTorrentVideoLAN - VLC media playerWinRAR
February 5, 201114 yr Author Careful what you removeThats just it, I dont remove anything.XML here<?xml version="1.0" encoding="utf-8"?><unattend xmlns="urn:schemas-microsoft-com:unattend"> <servicing> <package action="configure"> <assemblyIdentity name="Microsoft-Windows-Foundation-Package" version="6.1.7600.16385" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="" /> <selection name="Internet Games" state="false" /> <selection name="More Games" state="false" /> <selection name="Minesweeper" state="false" /> <selection name="Printing-XPSServices-Features" state="false" /> </package> </servicing> <settings pass="windowsPE"> <component name="Microsoft-Windows-Setup" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <DiskConfiguration> <Disk> <CreatePartitions> <CreatePartition wcm:action="add"> <Order>1</Order> <Type>Primary</Type> <Extend>true</Extend> </CreatePartition> </CreatePartitions> <ModifyPartitions> <ModifyPartition wcm:action="add"> <Active>true</Active> <Extend>false</Extend> <Format>NTFS</Format> <Label>SYSTEM</Label> <Letter>C</Letter> <Order>1</Order> <PartitionID>1</PartitionID> </ModifyPartition> </ModifyPartitions> <DiskID>0</DiskID> <WillWipeDisk>true</WillWipeDisk> </Disk> <WillShowUI>OnError</WillShowUI> </DiskConfiguration> <UserData> <AcceptEula>true</AcceptEula> <FullName>Testt</FullName> <Organization>Testing</Organization> </UserData> <ImageInstall> <OSImage> <InstallTo> <DiskID>0</DiskID> <PartitionID>1</PartitionID> </InstallTo> <WillShowUI>OnError</WillShowUI> <InstallFrom> <MetaData wcm:action="add"> <Key>/IMAGE/INDEX</Key> <Value>1</Value> </MetaData> </InstallFrom> <InstallToAvailablePartition>false</InstallToAvailablePartition> </OSImage> </ImageInstall> <EnableFirewall>false</EnableFirewall> </component> <component name="Microsoft-Windows-International-Core-WinPE" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <SetupUILanguage> <UILanguage>en-us</UILanguage> </SetupUILanguage> <InputLocale>0409:00000409</InputLocale> <SystemLocale>en-us</SystemLocale> <UILanguage>en-us</UILanguage> <UserLocale>en-US</UserLocale> </component> </settings> <settings pass="specialize"> <component name="Microsoft-Windows-Shell-Setup" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <OEMInformation> <Manufacturer>Test</Manufacturer> <Model>V2.01</Model> <SupportHours>24hrs</SupportHours> </OEMInformation> <BluetoothTaskbarIconEnabled>true</BluetoothTaskbarIconEnabled> <TimeZone>Pacific Standard Time</TimeZone> </component> <component name="Microsoft-Windows-UnattendedJoin" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <Identification> <JoinWorkgroup>MSHOME</JoinWorkgroup> </Identification> </component> <component name="Security-Malware-Windows-Defender" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <DisableAntiSpyware>true</DisableAntiSpyware> </component> <component name="Microsoft-Windows-IE-InternetExplorer" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <AllSitesCompatibilityMode>true</AllSitesCompatibilityMode> <BlockPopups>yes</BlockPopups> <CompanyName>Testing</CompanyName> <DisableFirstRunWizard>true</DisableFirstRunWizard> <FavoritesDelete>true</FavoritesDelete> <Home_Page>www.yahoo.com</Home_Page> <PlaySound>false</PlaySound> <ShowInformationBar>true</ShowInformationBar> <SuggestedSitesEnabled>false</SuggestedSitesEnabled> <Window_Title_CN>Testing</Window_Title_CN> </component> <component name="Microsoft-Windows-ErrorReportingCore" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <DisableWER>1</DisableWER> </component> <component name="Microsoft-Windows-powercpl" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <PreferredPlan>8c5e7fda-e8bf-4a96-9a85-a6e23a8c635c</PreferredPlan> </component> <component name="Microsoft-Windows-Printing-Spooler-Core" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <RemoveMXDW>1</RemoveMXDW> </component> <component name="Microsoft-Windows-SystemRestore-Main" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <DisableSR>1</DisableSR> </component> </settings> <settings pass="oobeSystem"> <component name="Microsoft-Windows-Shell-Setup" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <AutoLogon> <Password> <Value>UABhAHMAcwB3AG8AcgBkAA==</Value> <PlainText>false</PlainText> </Password> <Username>Administrator</Username> <LogonCount>2</LogonCount> <Enabled>true</Enabled> </AutoLogon> <BluetoothTaskbarIconEnabled>true</BluetoothTaskbarIconEnabled> <DisableAutoDaylightTimeSet>false</DisableAutoDaylightTimeSet> <DoNotCleanTaskBar>true</DoNotCleanTaskBar> <ShowWindowsLive>false</ShowWindowsLive> <TimeZone>Pacific Standard Time</TimeZone> <OOBE> <HideEULAPage>true</HideEULAPage> <NetworkLocation>Work</NetworkLocation> <ProtectYourPC>1</ProtectYourPC> <HideWirelessSetupInOOBE>true</HideWirelessSetupInOOBE> <SkipMachineOOBE>true</SkipMachineOOBE> <SkipUserOOBE>true</SkipUserOOBE> </OOBE> <UserAccounts> <AdministratorPassword> <Value>QQBkAG0AaQBuAGkAcwB0AHIAYQB0AG8AcgBQAGEAcwBzAHcAbwByAGQA</Value> <PlainText>false</PlainText> </AdministratorPassword> </UserAccounts> <VisualEffects> <FontSmoothing>ClearType</FontSmoothing> </VisualEffects> <StartPanelLinks> <Link0>%SYSTEM32%\calc.exe</Link0> <Link1>%SYSTEM32%\notepad.exe</Link1> </StartPanelLinks> <Themes> <WindowColor>Frost</WindowColor> <DesktopBackground>%WINDIR%\Resources\Themes\DesktopBackground\new.bmp</DesktopBackground> <ThemeName>NEW</ThemeName> <DefaultThemesOff>false</DefaultThemesOff> </Themes> </component> </settings> <cpi:offlineImage cpi:source="wim:c:/users/administrator/desktop/new%20folder/sources/install.wim#Windows 7 Ultimate x86" xmlns:cpi="urn:schemas-microsoft-com:cpi" /></unattend> Edited February 5, 201114 yr by _matt
February 6, 201114 yr You can delete these lines inside your Autounattend.xml, because there are not valid for Windows 7: <servicing> <packageaction="configure"> <assemblyIdentityname="Microsoft-Windows-Foundation-Package"version="6.1.7600.16385"processorArchitecture="x86"publicKeyToken="31bf3856ad364e35"language="" /> <selectionname="Internet Games" state="false" /> <selectionname="More Games" state="false" /> <selectionname="Minesweeper" state="false" /> <selectionname="Printing-XPSServices-Features" state="false" /> </package> </servicing> The BSOD appears sometimes when the Graphic Drivers are installed with Virtual Machine!When that appends to me I create a new time the ISO file and all is working fine! Edited February 6, 201114 yr by myselfidem
February 6, 201114 yr Author When that appends to me I create a new time the ISO file and all is working fine!Im sorry I dont fully understand what you are saying. Are you changing the time on the made/created of the ISO?
February 6, 201114 yr Im sorry I dont fully understand what you are saying. Are you changing the time on the made/created of the ISO?I was talking about the BSOD with Grphic Drivers appends sometimes with the Virtual Machine!
