CPU Usage 100% When Opening Video folder
Hi guys
I'm using Windows 7 Ultimate 32bit
When I open my Video folder , my CPU usage goes to 99-100%.
Task manager indicates Explorer.exe is the process using 99% of this.
It remans 99-100% until I close explorer.exe and after I restart.
I don't know why Exporer.exe would suddenly start using all my system resources when I open a video folder. :confused02:
After I read maybe the problem is FLV video...
Any ideas?
I would try uninstalling it see if the problem continues
If the problem goes away I would then reinstall the codec pack and separate the different file types (avi, flv, mkv, etc) and see which one is the cause the high cpu usage
I think it may be a explorer thumbnail issue
Thanks for your help. :thumbsup_anim:
It was codec problem.
Now I can open any video folder.
