September 5, 201114 yr Questions, questions, questions ... I am trying to figure out how W7T works. The first few questions are primarily aimed at Legolash2o, so these may be fitting for an additional W7T guide. The last I am just curious if anyone knows the answers to.1. Windows 7 setup pulls froms the install.wim on the install DVD. Tweaks are integrated into the install.wim source using W7T. 'Local Machine' tweaks obviously apply to the whole system. How are 'Current User' tweaks applied? Does that go to a 'default user', or are the tweaks lost when the first user is created?2. Silent installers that are setup by W7T are run in what context? Does the 'Default User' apply here or are the settings saved to a 'System' account?3. Applications that are integrated into the install source, where does each program's 'Current User' settings go ('default user' maybe)?Questions not directly related to W7T:4. What context does the 'setupcomplete.cmd' file run in?5. What is the best way to set up "Run Once" installers (from setupcomplete possibly)?
September 5, 201114 yr 1. They pretty much go to HKEY_Users\\Default so they are created for every new user.2. W7TRunOnce gets copied into system32 folder. It scans HKLM\\Software\\W7T for what apps it needs to install with their switches3. Same as 1.4. Never used it, someone else may have to answer that, but i know it runs during OOBE i think.5. Again, not sure. Never used it setupcomplete.
September 5, 201114 yr Author 4. Never used it, someone else may have to answer that, but i know it runs during OOBE i think.5. Again, not sure. Never used it setupcomplete.Thank you for that useful information. Likely, the last two are also applied to the 'Default User' as I believe they run before the user first gets logged in. But right now, that does not seem to matter as the other items fulfill my needs as they are applied to everyone that logs in. This information might need to be added to a user guide or something, but it will do great for me right now. Thanks again!
February 27, 201213 yr what command line switches dose it support?trying to intergrate all this into a wim where i dont need a dvd / usb pxe setup here. Edited February 27, 201213 yr by dw5304
February 28, 201213 yr what command line switches dose it support? trying to intergrate all this into a wim where i dont need a dvd / usb pxe setup here. Give me a list of what you integrated..This may be caused by a addon of mine.. Used to implement them a certainway, and it has since changed.. I have been updating them to take care of this problem.
March 1, 201213 yr was with the Reapers_.NET_Framework_4.0.30319.1_x64_Windows7_Toolkit_AddOn.WA Thats what i thought as well i went and edited the registry in the wim to say C:\ but it still is looking for a D drive .I allready got ie9 and all the updates would just be nice to add the .net into the mix. . Edited March 1, 201213 yr by dw5304
March 1, 201213 yr I just updated that one a few days ago...Just add the new one to the silent installer section in windows 7 toolkit....
