Problems with MSU 2 CAB adding KB947821 x64
Hello,
I have a small problem while converting "Windows6.1-KB947821-v14-x64.msu".
The msu file has a size of 330.913.139 bytes.
When I try to convert it to cab, it seems to be converted ( green background ), but the cab file has a size of 16.809 bytes.
Does anyone has the same problem ?
Thanks,
caphp
Are you using a Win7 SP1 source? If you are, it would appear that update is not needed. I do not even have that update listed as needed.
I'm using W7 with integrated SP1.
It seems to be for W7 without and W7 with SP1 ...
This tool is being offered because an inconsistency was found in the Windows servicing store which may prevent the successful installation of future updates, service packs, and software.
and
Supported Operating Systems: Windows 7, Windows 7 Service Pack 1
Also, please note this is a Tool, not an actual update. Even if you do download it, you don't integrate it in your source, you run it on a live system so it can check for potential problems.
Edited by bphlpt
Ok, but the Update was displayed to me unter "Windows Updates" ( the optional ones ) and so I downloaded and installed the KB947821.
So to me there is no question, if I should install it or not.
I just want to know, if there is a general problem with converting this msu or is it only a problem which appears on my computer ?
Best regards
  • 1 year later...
Hello
I have windows 7 X86 and X64 with and with out SP1 and this updates comes and want to
be updated when windows is install. i have try manye programs and so on. it seems that
you can only run it in Setupcomplete.cmd and cannot slip stream it into .wim file sadly.
