.WA Icon
Got fed up with .WA files being a blank white icon. Means you have to read. A proven fact is that you use visual identity first to attract your eye then read after.
To this end, my attempt at making an icon for .WA files. Drop it where you will, Change the path to your icon location in the reg file (as below), merge to registry. Voila! Instant spotabilty of your .WA files!
[HKEY_CLASSES_ROOT\.wa\DefaultIcon]
@="C:\\Path to\\your icon\\location\\WA.ico,0"
The reg file in the zip points to your C:\Windows folder. Edit as you will.
WA Icon.zip
Very nice, Elmer! When he has the chance, I think Liam should incorporate and include this with Win Toolkit. Kind of continuing the "brand" of Win Toolkit.
