May 10, 201213 yr hello friends the extension given to the addon. wa belongs to an audio file?read:http://filext.com/file-extension/WAGreetings! Edited May 10, 201213 yr by jonydread
May 10, 201213 yr But that file type was abandoned over 14 years ago:WavArc is another abandoned lossless compressor. It was developed up to 1997So I don't think that it now being used by WinKit will cause any problems, do you?Cheers and Regards
May 11, 201213 yr Author causes no problem, just saw that information and I remain in doubt whether any problems could cause future but as this abandoned not think so.thanks!
June 6, 201213 yr Even if a user does still use that program, it only changes the icon so any file associations should still be the same. Thanks for the concern anyway
