[Addon] Bashrat Drivers Background Displayer V2.5
Hi all
i finally released my own addon that should be working
i tried to make it using entries only but failed so i`m back in using inf until i make it work right
what this addon do
this one show a background while Bashrat's driver packs are unpacking
this addon is based on Nightwolf81 work in here
picture of the screen of setup
Download
MD5 : 8560803C3E7B7C12489DBA69F94ECF44
need feedback
Note:
This addon Features
1-Fixed The themes background not applied problem
2-The install Driver picture is removed before windows starts
3-The Inf file is removed too so no need to clean things after this addon
4-This addon doesn't require The vista Orb addon every one of them works separately
ChangeLog
17-11-2008
Fixed Entries in some problems
12-11-2008
Fixed a typo
Removed some unneeded commands
Edited by DaRk MaDnEsS
thanks ... I will give it a try ... but I kinda think this will apply the image to 1st Desktop view.
I am trying to get a background image to show during DriverPack installation; but I want my own Desktop Wallpaper to apply on 1st Desktop view......(not the DriverPack background)
I tried an earlier addon that worked fine for DriverPack installation ... but applied postage size wallpaper of same image on Desktop .... my Wallpaper that I was applying with default theme
got kicked off ....lol.
I have had a look at the inf/ini files in this addon and it looks very similar to the one I tried before... but I will give it a go the next time I run a new slipstream.
many thanks ;)
many thanks ;)
i know the problem
i fixed the same problem in my own Vista Start up Orb here and it should be working as well
in here
just give it a try and tell me i tried and it worked
but need more tests
well looks like I'm the 1st tester and I'm sure glad I did.
AWESOME!!!!!!!!! :thumbsup_anim: :thumbsup_anim: :thumbsup_anim:
must admit when I looked at the ini/inf files, I thought hmmm dunno .....but works perfect
1st picture is Driver Pack Display Picture (I used my own)
2nd picture is first Desktop View from install with my own Wallpaper as background
Thankyou so much ... fabulous work :prop:
well the fix i added is simple just to make it do the job then remove it
right now i released v.2 i just removed some unneeded commands
but i`m testing them right now
it should work as well
and thx for the test and glad it worked
edit 1: hmm some problems happended when i used v 2 i`m fixing it now so every one wait for now
Edit2: Fixed A little Type in commands and v2.1 is back to work
plz Re Download
Thanks Dark Madness. Concidering that I'm still a newbie with XP costumising, it was annoying for me to see that light blue background during the installation. WolfCall is the greatest addon maker I know and he said your addon works fine. So common testers (me included), let's give this addon a try. :)
well in first place he didn't believe it might work
:icon_cool: but i guess he was happy to see it actually working
you can try it live or in virtual it should be working
and thx for answer
Posting back
Working 100% perfect here dude no problems this time with the picture displaying on the desktop after an unattended install
nice job dude :icon_cool:
Edited by sT0n3r
The addon works excellent (I changed the background only). Thanks again. ;)
glad to hear this confirmation
seems the addon doesn't have any problem with any one ...
i guess no need for need tester word any more thx every one for your feedback i`m glad you liked the addon
hmm some problems seems to happen for some ppl that uses RVM intergator 1.5.3 or less
this version should fix some issue but it`s no problem to use old version
One thing I found with this addon during beta testing the RVMI, is that you use [editfile] to modify hivedef.inf when you should be using either [extrafileedits] or a combination of [keydelete] prior to [editfile]. The reason is because all three of your regedit entries are duplicated in hivedef.inf, they're just added to the end instead of replacing the existing lines. It shouldn't cause any problems, because the file is parsed in order (ie. change A to B, now change to C.)
Not a bug, but could be cleaner. :)
well the problem that made me use [editfile] that in some of my windows cd i didn't find those registry
so it didn't replace them but yesterday i was reading more about entries and there should be some tests today (after i finish today`s exam)
and thx for the info Mr_Smartepants
I have tried your addon for the driverpacks background and I have a question. You know that a person gets that same blue screen when DriverPacks Finisher is running just before it loads the chosen default desktop theme, is it possible to incorporate a background picture to replace that screen. I have given it some thought and toyed with the idea that a registry tweak might do the trick, however I think it may take more than that. Any ideas?
Edited by EagleWing
