January 4, 200719 yr Recycle Bin Start Menu by prx984Adds The Recycle Bin to your start menu, also adds check box in Start Menu Properties and Folder Options to show/hide the Recycle Bin Icon in both Start Menu and DesktopMD5: 9DC8D6BCFA9DBD00B7949829BA34217DSize: 2.30 KBWebsite: http://www.wincert.net/forum/index.php?showtopic=552Very special thanks: Cygnus, Tom, VA(s)T, oxcoxp, Arnab and Sanjay for all your smartsCCleaner Users:; ### CCleaner Users Edit/Remove the SemiColon from the begining of the RegEntries;HKCR,"CLSID\{2559a1f6-21d7-11d4-bdaf-00c04f60b9f0}\Shell\Open CCleaner...\command",,0,"%16422%\CCleaner\ccleaner.exe";HKCR,"CLSID\{2559a1f6-21d7-11d4-bdaf-00c04f60b9f0}\Shell\Run CCleaner\command",,0,"%16422%\CCleaner\ccleaner.exe /AUTO"Changelog:01/24/07 v0.4Removed Rename From Context MenuAdded Optional Lines for CCleaner users Right Click Context Menu01/20/07 v0.3Added Empty Recycle Bin to Context Menu (thanks to Arnab)Slimed down RegEntries (thanks to Sanjay)01/12/07 v0.2Added Right Click: Properties, Rename, Open and Explorer entries to Recycle Bin shortcut (thanks to oxcoxp, only Empty Recycle Bin left )
January 4, 200719 yr Thats twice now I've done that (check a topic, think about replying, get side tracked )Anyway, thanks Rick. I gotta try this (hopefully tomorrow, it's late here and I'm tired). I will try this on a VPC, then I will burn a new nLite disc.
January 12, 200719 yr Author Updated... Added Right click Options, Open, Explorer and Rename entries (thanks to oxcoxp)
January 12, 200719 yr OOOHH! This is kool, can't wait until "Empty Recycle Bin" option is added Thanks rick for continuing to work on it
January 13, 200719 yr I've asked rick before to add this option but he told me that it is not that easy, hope it came true
February 21, 200719 yr Rick, I hate to say this, but how do I integrate this? I did it before, but now I forget :lol:Edit: LMAO nvm, I figured it out within 2 seconds of posting this Edited February 21, 200719 yr by cygnus
May 5, 200719 yr Hi Ricks, I tried out this addon but its not working. Does it required any special method?
May 5, 200719 yr Author Right click on the Start Menu and choose PropertiesNow hit Customize... and go to the Advanced tabScroll down and tell me if you see a Recycle Bin Check box like this one
May 10, 200719 yr CCleaner Users:; ### CCleaner Users Edit/Remove the SemiColon from the begining of the RegEntries;HKCR,"CLSID\{2559a1f6-21d7-11d4-bdaf-00c04f60b9f0}\Shell\Open CCleaner...\command",,0,"%16422%\CCleaner\ccleaner.exe";HKCR,"CLSID\{2559a1f6-21d7-11d4-bdaf-00c04f60b9f0}\Shell\Run CCleaner\command",,0,"%16422%\CCleaner\ccleaner.exe /AUTO"hi rick! leme understand this correctly, if i use cclear (your addon too ), i need to modify reg entries as specified above? please correct me if i did this incorrectly ... i extracted both contents of the addon & removed the colons & saved the changes ... i then compressed the files again using 7zip (as opposed to the rar format used in the orig addon) ... then renamed it as is ... would this be right and ready for integration? i'm just thinking, would it be alright to have the same addon but with the ccleaner edit already incorporated? thanks! Edited May 10, 200719 yr by kiki burgh
May 10, 200719 yr How do I set this recycle bin start menu automatically enable on start menu without manually set on customize menu?
May 10, 200719 yr Author @Kiki, yes you did it right, you edited it correctly @Yadzil, you don't have to, this addon is supposed to show the recycle bin in your Start Menu. My only guess is that you are using Kels UberPack. He already includes this tweak but he stets it to turn off by default
May 11, 200719 yr @Kiki, yes you did it right, you edited it correctly thaks rick! i'm happy i finally did something right for repacking an addon (i really am interested in learning more about addon creation ) ... i tried the repacked addon of course without altering anything else (aside from the colon removal & compression format) to preserve the credits and indeed i already have the Recycle Bin check box in the Start Menu properties ... if i guess it correctly, it'd only work of no tweak is applied to the Recycle Bin (i.e, renaming/deleting it) ... atm, i have my Recycle Bin renamed as "My Shredder" and it wasn't moved away from the desktop ... could there be some adjustments made to this addon? thanks rick!
May 11, 200719 yr Emm, So how should I automatically turn it on without exclude uberpack or without your addon , Rick?
May 11, 200719 yr Author Yes you can enable renaming this recycle bin in your start menu also... Remove the semicolon from this line; ### Renamable Recycle Bin on Start Menu (REG_BINARY);HKCR,"CLSID\{2559a1f6-21d7-11d4-bdaf-00c04f60b9f0}\ShellFolder","Attributes",0x00000001,50,01,00,20The reason I turn this off is that when you rename the recycle bin in the start menu a second recycle bin pops up on your desktop(don't worry it disappears when you refresh your desktop)
May 11, 200719 yr thanks rick! so does this mean that even if i already have Recycle Bin renamed (renamed it to My Shredder) via my personal reg tweak, the addon will be able to identify that as my real Recycle Bin?
May 12, 200719 yr hi rick! did just what you instructed me to ... however, i got 2 Recycle Bins now ... the 1 on the desktop didn't go away (or wasn't hidden) even if after refresh or even reboot ... he! he! how do i nail this 1? just an fyi, my tweak for Recycle Bin is as simple as renaming it to My Shredder via my own .reg file ... i'm thinking what if i add some more tweaks via nLite (i.e., deleting Recycle Bin or Hiding Recycle Bin) ... i guessing it might just conflict with this addon? thanks!
May 12, 200719 yr Author Add your recycle bin name here to this line HKCR,"CLSID\{2559a1f6-21d7-11d4-bdaf-00c04f60b9f0}\Instance\InitPropertyBag","Command",0,"@%%SystemRoot%%\system32\SHELL32.dll,-8964"
May 12, 200719 yr hey rick! i'm really sorry ... you mean change this entire string to "My Shredder"? thanks!
